Glissando Gizzmo
Audio files: 150
PostPosted: Fri Apr 22, 2005 7:42 pm    Post subject: Glissando Gizzmo Reply with quote  Mark this post and the followings unread
Here is a little patch that is sorta fun. It's a glissando gizzmo. You can set the step size, and the upper and lower limits. There are lots of improvements one could make to this cricuit.
For example, the step size could be controlable over a certain range by a CV. Better yet, the step should be randomly selectable with higher probability for the small step sizes. Also, there needs to be another control input to force the glissando to switch directions.
Maybe other people will be able to improve this thing.
The block itself is in yellow.
Gliss Gizzmo.pch2
A glissando gizzmo building block.
 Filename:  Gliss Gizzmo.pch2
 Filesize:  1.53 KB
 Downloaded:  2224 Time(s)
