Here's a straight clip. The bass is from the Braids in 'FOLD', the lead from the Orgone Accumulator (which has Position being modulated by Y from the Jerkster, but that's it.) All CV from the Klee sequencer (side A to the Braids, side B to the Orgone.)
Same as the first clip, except that the bass from the Braids has it's Timbre modulated by the X cv from the Jerkster. Orgone, no modulation (except for Position, which is pretty dang subtle in all these clips compared to what it can do.)
This is with ALL modulation going! The Z cv from the Jerkster is controlling the Detune CV in the Orgone Accumulator now, which does what you'd think -- it constantly detunes the pitch by a varying amount (supplied by the chaotic Jerkster, in this case, again more subtly than what it can do.) The Y output is controlling the Orgone's Position, which crossfades between three different waveforms. The X output is controlling the Braids' (doing the bassline) timbre.
This is with the clock on the Klee stopped, so the two oscillators are stuck droning their note. This gives you a much better idea of the Chaos element of this, and is probably the standout clip to show off the Jerkster out of the four.
