Coming up on Radio 1 at
 Forum index » electro-music.org » Streaming Radio Station
NYE live streaming event
Page 3 of 3 [62 Posts]
Goto page: Previous 1, 2, 3
EdisonRex
Audio files: 172
PostPosted: Thu Dec 31, 2020 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Tony, can you please check in? You got 14 minutes...
Garret: It's so retro.
Audio files: 163
PostPosted: Thu Dec 31, 2020 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is my Epicyclus set , thanks to phobos for setting up & thanks to jan for testing levels & Jez for switching me ,
usuall gear used plus a few new bits a twin TD3 setup and an argon 8M
Thanks for listening in Smile
Epicyclus NYE dec 2020 into 2021.mp3
 Filesize:  28.01 MB
 Duration: 30:35
 Viewed:  3078 Time(s)
Acoustic Interloper
Audio files: 90
PostPosted: Thu Dec 31, 2020 1:09 pm    Post subject:
Subject description: photo for my 01:00 GMT set
I forgot about posting a pic for display during my upcoming set. Here's a splash screen for a video that is playing in an on-line conference art gallery.
Cover for Photosynthesis video
 Filesize:  2.26 MB
 Viewed:  658 Time(s)
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
klangumsetzer
Audio files: 37
PostPosted: Thu Dec 31, 2020 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the groovebox gymnastics I used my trusty Yamaha CS01 with a Cooper fx Arcades pedal together with a Roland MC-505.
Thank you PHoBOS for organizing and the nice flyer, jan for testing, paul for switching and all the good people at electro-music.com for listening!
edit: now with complete mix
2021 new year event_klangumsetzer.mp3
(C) 2020 by klangumsetzer
 Filesize:  61.92 MB
 Duration: 30:56
 Viewed:  3130 Time(s)
Make a joyful noise!
Eike
Ron Holmes
Audio files: 19
PostPosted: Thu Dec 31, 2020 9:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is my set from today. Thanks to all who helped set this up and to Jan and Jez for taking care of me. Ron
Escape Velocity Live New Years Eve 2020.mp3
 Filesize:  31.94 MB
 Duration: 29:38
 Viewed:  3128 Time(s)
PostPosted: Fri Jan 01, 2021 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a recording of my NYE 2020 set.
It is an exploration of timbres in an ambient/drone/sustained setting.
Note that I didn't use keyboards or loopers and only used the modular (analog) synthesizer with an outboard effects unit (a DPS-V55) to create the space.
Thank you to the event organizers, stream operators, and participants for enabling these events.
Improv for NYE 12_31_2020.mp3
Drone/Ambient Improv for NYE 12/31/2020
 Filesize:  66 MB
 Duration: 28:50
 Viewed:  3155 Time(s)
EdisonRex
Audio files: 172
PostPosted: Fri Jan 01, 2021 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording of my set. It was an excellent event, just lots of quality music and for hours. Thanks to all.
NYE2020-EdisonRex.mp3
EdisonRex (Paul Harriman) - NYE-2020
 Filesize:  53.15 MB
 Duration: 58:03
 Viewed:  3125 Time(s)
Former site admin
Audio files: 353
PostPosted: Fri Jan 01, 2021 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Had forgotten to record my set and made a new one, it should be about the same .. except that for me this one does not have the stress of broadcasting it live.
Posted Image
The patch I've used:
Posted Image
2020-12-31--Blue Hell--2020 NYE - happiness is moments.mp3
 Filesize:  27.61 MB
 Duration: 29:34
 Viewed:  3319 Time(s)
Acoustic Interloper
Audio files: 90
PostPosted: Fri Jan 01, 2021 2:16 pm    Post subject:
Subject description: Acoustic Interloper Set
Balance. The piece is based on a chord sequence that I have been finger-picking-arpeggiating for a few years, never used in a performance before:
Dm A C G Bb F C Dm.
My wife & son and also several people in my port check noticed some similarity to the progression in the Eagles' Hotel California. It also has some overlap with the progression of Black by Danger Mouse and Daniele Luppi, sung by Norah Jones, and used once or twice in the TV series Breaking Bad, but Balance is identical to neither. In fact, there is a 2nd variation of
Dm A F G Bb F C Dm,
substituting an F for the first C. It just sounds better in that middle fret position.
My idea after playing the initial progression was to move away from "playing the changes" and instead improvise modal-jazz-style over a single chord from that progression for an extended period. Before that, though, I live-recorded the progression from 00:00 to about 02:00, then played it back and dueted using inversions of the recorded chords. The original ascends from the nut twice, then descends from the 10th fret twice, then descends from the 7th fret using the F substitute chord. When I layered the duet in real time, I descended when it ascended (using chord inversions), ascended when it descended (again inversions), and doubled with it on the substitute F section. The result sounds a lot like the chorusing you get with electric 12-string guitar, except over an entire chord instead of over individual notes. The duet runs from Marker01 to Marker02 on the Audition screen shot.
The only editing was trimming dead space at the start and a few seconds manually going into Marker01. I listened to the effect of increasing amplitude starting at Marker02, but I verified an interesting effect that I've known with my ears and I guess intellectually. Even though the amplitude in terms of signal levels drops off at Marker02, the harmonic content is much different because of the inclusion of two no-input mixers. From Marker02 to Marker03 sounds roughly as loud to me as the sections that precede Marker02 because of harmonic content, which is somewhat counterintuitively in the low frequency range. The mixers add a lot of low-end noise. See FFT screen shot, with pre-Marker02 on the left and post-Marker02 on the right. I left the recorded levels unchanged in the posted recording. I think part of the lesson here is to avoid over-reliance on VU meters alone is estimating loudness.
My rig consisted of a Godin xtSA, mostly used as an electric guitar, although I did feed its synth signal live to a Roland GR33 guitar synth playing the "Perc Kit" patch for the drum sound starting at Marker03. Signals fed into Ableton Live. I precorded a simple looped strum of each chord, separately, using the MIDI output of the GR33, and turned them into click tracks (D note, Dm chord, and F chord used in the performance), driving Applied Acoustic Systems' StringStudio strumming a Koto patch (more percussive click) and an AAS Chromaphone Smooth Carillon patch (tinkly). The banjo part from Marker05 to Marker06 was the only non-click-track precorded part. It is a Bart Reiter open-back Professional model with the internal wooden resonator that acts as an equalizer. I didn't want to mess with a mic and instrument change during the performance. The two no-input mixers are my workhorse Yamaha MG124cx and Galaxy Audio AXS-10, both starting with straight analog feedback and then dialing in some in-loop digital delays.
Thanks so much to PHOBoS for setting this up & managing, also Jan, Jez and Paul for switching duties, to everyone who played and listened. Happy New Year!
EDIT 1: Also used an EBow in obvious places, and a Live granular patch that echoes a played note down a minor third, and that note down a minor third, etc., until it decays. I also copied & edited to get a patch that drops to the 5th below for modulating to a major scale. Playing the EBow in a single position against the minor-third delay is interesting, because it continuously reinforces the primary note, with the descending intervals continuous in time, creating sort of a sonic fabric across that scale.
DaleEParsonBalanceNYE20202021.mp3
*Balance*, Copyright 2020, Dale E. Parson, Creative Commons Attribution 4.0 International (CC BY 4.0), copy with attribution.
 Filesize:  26.54 MB
 Duration: 28:59
 Viewed:  2949 Time(s)
my rig
 Filesize:  7.76 MB
 Viewed:  599 Time(s)
Adobe Audition levels. Read & discuss.
 Filesize:  365.16 KB
 Viewed:  483 Time(s)
 Filesize:  641.15 KB
 Viewed:  503 Time(s)
PostPosted: Tue Jan 05, 2021 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Once again, I could not listen live nor participate, but I listened to all the recordings posted in this thread, and there's some great stuff! Thanks.
.: james :.
Acoustic Interloper
Audio files: 90
PostPosted: Tue Jan 12, 2021 11:30 am    Post subject: Dox the Coup
Subject description: Zero-input (no-input) mixer follow-up to NYE
While my mixers were still set up from NYE I prepped, played, and posted a one-hour no-input mixer piece called Dox the Coup.
Audio files: 282
PostPosted: Sun Jan 24, 2021 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Life's been a bit busy of late and I seem to be behind with uploading of things, but here at last is my set Smile
modulator_esp_e-m_NYE_2020_time_distortion_overload.mp3
Modulator ESP - e-m NYE 2020 - Time Distortion Overload
 Filesize:  55.57 MB
 Duration: 1:00:42
 Viewed:  3019 Time(s)
