 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - automatic (noodles)
Pianodrone
Page 1 of 1 [12 Posts]
Dadooronron Ron
G2 patch files: 21
PostPosted: Wed Jul 06, 2005 3:42 pm    Post subject: Pianodrone Reply with quote  Mark this post and the followings unread
When I was whining once about not being able to play my piano, Jan told me to build a machine to do it for me.
So the following patch is also a bit Jan's fault...
***Internal MIDI alert! - Please load in slot A***
(And keep the rest of the slots clear; this one needs to allocate some voices!)
Pianodrone.pch2
 Filename:  Pianodrone.pch2
 Filesize:  5.71 KB
 Downloaded:  1916 Time(s)
Last edited by Dadooronron Ron on Wed Jul 06, 2005 3:55 pm; edited 1 time in total
Audio files: 278
PostPosted: Wed Jul 06, 2005 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
This aint no fault I regret :-)
I bet this player could play other intruments as well ...
Are you having a patching holiday or something ? What an enormous outbreak of patches I mean ...
Jan.
Dadooronron Ron
G2 patch files: 21
PostPosted: Wed Jul 06, 2005 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan, to be honest, I'm a bit scared by this sudden productivity too...
By the way... Made a last minute update. Nothing big; just changed one LFO from saw to triangle but it's much better this way. So be sure to get this version. (Sorry)
G2 patch files: 626
PostPosted: Wed Jul 06, 2005 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thats very nice playing, a great piano as well.
cebec
G2 patch files: 31
PostPosted: Wed Jul 06, 2005 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice one, ron! i really like the tone and this particular piano 'voicing'.
Audio files: 212
PostPosted: Wed Jul 06, 2005 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice melody generator. The selection of different keys makes for some interesting patterns. Very cool. Cool
Audio files: 212
PostPosted: Wed Jul 06, 2005 8:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a performance with two copies of this patch. In SLOT A the piano is transposed up 1 octave and in SLOT B it is transposed down 1. Also, the patch levels has been cut by 50% (two parts). I backed off on the stereo chorus on the left hand part.
Now we have a beautiful composition. Sounds Chopinesque, sorta. More dreamy if that is possible, or maybe just psychotic. If you played it live you would be well received, assuming that at some point you stopped and took a bow. Laughing
pianodrone.prf2
Two patches by Dadooronron Ron
 Filename:  pianodrone.prf2
 Filesize:  12.61 KB
 Downloaded:  2863 Time(s)
Dadooronron Ron
G2 patch files: 21
PostPosted: Fri Jul 08, 2005 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Howard, I took the liberty of messing around with your performance a bit. The only thing remaining in slot B is the player which is now in the same key as the one in slot A (although you may not want that, being the excentric person that you are Wink ). This squeezes out three extra voices, avoiding some (not all) nasty "twangs" when two notes collide in the string oscillator. Although this might not be a problem on an expanded G2; I don't know. Transposing is now taken care of in the midi note send module.
If I might make another suggestion: take the original patch and increase the rate of LfoA2 (somewhere in the FX area) to about 3 Hz. At 4 Hz the piano gets stressed (twang!) occasionally, but then again, I'm not expanded yet.
pianodrone[1].prf2
 Filename:  pianodrone[1].prf2
 Filesize:  9.81 KB
 Downloaded:  1670 Time(s)
Audio files: 278
PostPosted: Fri Jul 08, 2005 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
It would give you 26 voices, I turned up LFO2a to about 6 Hz, and LFO1a to 4.57 with a random wave selected - wow this guy can really play :-)
Hmm, Rob made a granulizer once, ah got it. Now that messes things up nicely again :-)
Jan.
pianodrone_1_-1-gr.prf2
Granulized a nice patch made by Ron with Rob's help
 Filename:  pianodrone_1_-1-gr.prf2
 Filesize:  15.83 KB
 Downloaded:  2500 Time(s)
Dadooronron Ron
G2 patch files: 21
PostPosted: Fri Jul 08, 2005 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm. Well, this certainly hides the flaws of the piano quite nicely.
Sounds a bit like a Balkan-orchestra on dope (the mellowing kind, that is).
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sat Jul 09, 2005 11:09 am    Post subject: Another pianodrone Reply with quote  Mark this post and the followings unread
Wow Ron! This "piano player" is very good - better at the keyboard than me!
I wanted to let him play my piano patch. I also gave him a sustain pedal to use.
It's back to patch mode and designed for Slot A.
PianoDrone VM.pch2
Ron's Player with my piano patch
 Filename:  PianoDrone VM.pch2
 Filesize:  7.9 KB
 Downloaded:  2068 Time(s)
varice
Dadooronron Ron
G2 patch files: 21
PostPosted: Sun Jul 10, 2005 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just one ...
Again more of the same; this performance generates some accompanying moody chords as well.
Unfortunately, for us expansionless guys, this performance is suffering a bit from the overstressed stringosc syndrome (o.s.s. as we doctors call it) I mentioned earlier...
PianoChords.prf2
 Filename:  PianoChords.prf2
 Filesize:  9.99 KB
 Downloaded:  1605 Time(s)
