Fun with shift registers
Page 1 of 1 [2 Posts]
Audio files: 148
PostPosted: Wed Sep 20, 2006 3:17 pm    Post subject: Fun with shift registers Reply with quote  Mark this post and the followings unread
The topics about the Klee sequencers are very intersting. I have played with shift registers for a long time. They are really lots of fun. Here is a very simple patch that uses one 8 bit shift register as the source for the notes.
You can load the SR by manually pressing a button, or by letting the SR check a LFO. You can also clear the SR. This is done with the 4 stage push button switch.
The first 4 bits of the SR go to a 4 bit ADC. The last 4 bits go to a second ADC. The way they are hooked up, it should be aparent that second ADC's output is the same as the first, but delayed by 4 clock cycles.
I have run the ADCs into a coupld of control sequences so you can see a readout of the outputs. You can see that even though the output appears to be random, the second voice is a canon - delayed version of the first.
This is meant as a demo, not a finished patch. I hope you enjoy it and maybe start using shift registers more in your patches. Maybe you'll invent the next sequencer...
Shift reg fun.pch2
Demo of some fun you can have with a shift register in a patch.
 Filename:  Shift reg fun.pch2
 Filesize:  2.38 KB
 Downloaded:  2083 Time(s)
Joe Misra
PostPosted: Sun Oct 08, 2006 9:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm finding this very fun indeed Very Happy
eerik inpuj sound - http://www.inpuj.net/
