Coming up on Radio 1 at
Tempco-less VCO -- What is it worth?
Page 1 of 1 [6 Posts]
françois
PostPosted: Tue Nov 27, 2007 1:53 am    Post subject: Tempco-less VCO -- What is it worth? Reply with quote  Mark this post and the followings unread
I've come across this app-note from National Semi, I guess many of you were already aware of it:
http://www.national.com/an/AN/AN-299.pdf
(AN-299 Audio Applications of Linear Integrated Circuits)
They describe an exponential (V/oct) VCO built around a CA3046 transistor array, which they claim achieves 0.25% linearity without any tempco element. In fact they use one transistor as the exponential element, and the others as a servo loop (temp sensor + heater). Reminds me of the (defunct) uA726.
Since I have no lab, not even breadboard, at hand, I would like to know if anyone of you has tested this circuit, and how it actually performs.
Thank you for any advice.
andrewF
PostPosted: Tue Nov 27, 2007 2:11 am    Post subject: Reply with quote  Mark this post and the followings unread
some EFM VCOs had the 3046 `chip heater` option. I cannot give any opinion on them tho, I have only built tempco versions.
Peake
PostPosted: Tue Nov 27, 2007 9:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I believe that the Moog Prodigy uses the CA3046 for a heated trannie pair.
Doesn't Oakleysound offer a Prodigy VCO board? Someone does.
françois
PostPosted: Wed Nov 28, 2007 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you.
I've come across a few VCO schematics that make use of a similar technique for chip heating. I think I'll give it a try as soon as possible.
I have to admit I don't like using a tempco resistor, the thermal paste and all that... I prefer having a chip at a given stable temperature. Of course, it can only be as good as the matching of the trannies on the chip, which can vary quite a lot. But the 3046 is (much) cheaper than the µA726 was...
françois
PostPosted: Thu Nov 29, 2007 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I could check that the Moog Prodigy does make use of a 3046 array for temperature regulation via chip heating. The circuit is very well explained in the Service Manual, which I checked out at
http://www.freeinfosociety.com/electronics/schempage.php?cat=1
Maybe you already know this site? It is full of schematics & service manuals for plenty of audio equipment, not only synthesisers, but also effects, amplifiers...
Peake
PostPosted: Sat Dec 01, 2007 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that's a great site!
