what diy stuff did you do as a kid?
Page 2 of 3 [64 Posts]
Audio files: 25
PostPosted: Thu Jan 03, 2008 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
In case anyone is interested in listening to a Chord EGG from PAiA or learing more, see and hear the attached items:
Bill
EGG_Track 1_ex1.mp3
 Filesize:  4.84 MB
 Duration: 7:32
 Viewed:  3411 Time(s)
 Filesize:  35.53 KB
 Viewed:  17516 Time(s)
RF
Audio files: 28
PostPosted: Fri Jan 04, 2008 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I like that Smile
I've never heard of this - What parts are involved? I see LSI mentioned - that does not sound promising to recreate it. Is there a schematic around?
bruce
sneakthief
PostPosted: Fri Jan 04, 2008 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
this PDF goes into details about the "Top Octave Generator" and mentions that the Chord EGG uses it something along the lines of a Mostek
MK50240.
Don Lancaster’s Hardware Hacker
http://www.tinaja.com/glib/hackar3.pdf
And here's a pic of the PCB:
Posted Image
Sneak-Thief - raw electrofunk
TheAncientOne
RF wrote:
I like that Smile
bruce
Anders amazing site has it:
http://rubidium.dyndns.org/cag/pdf/egg.pdf
The problem part is the obsolete MK50240 top octave synthesizer chip. This is a frightening price as NOS.
I'm looking aroung for an updated PIC design. Jim Patchell did one, but it's about 4 octaves down, due to processor speed. I've heard of an AVR version but can't find it. Best suggestion I've heard so far is a small CPLD or FPGA, though that means a lot of design work.
Mike
bugfight
PostPosted: Fri Jan 04, 2008 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I remember that, it was marketed here under the Braun brand, but in the US as something else. Didn't have it myself, and it was a bit limited indeed, but I've always liked the concept; not building a circuit but drawing up schematics really.
i bet that's the one, i don't remember what it was called...
forgot to mention the schematic thing. the blocks had the symbol on top so at the end you had the circuit and the schematic in one, which was not a bad idea. some of the "components" were nothing but wire connecting the terminals. you had to have a lot of blocks to do anything interesting (which i didn't of course)...
bugfight
PostPosted: Fri Jan 04, 2008 9:16 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="State Machine"]
hehe i also remember making an arc lamp ..."top up a pot" ...
LOL.
i never pissed in mine, i think that would have killed me for sure. it was totally homebrew too, with the "electrodes" being just bare wire, which did indeed corrode badly...
i had a friend, though, who pissed on an electric fence once...
once!
Audio files: 25
PostPosted: Fri Jan 04, 2008 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm looking around for an updated PIC design. Jim Patchell did one, but it's about 4 octaves down, due to processor speed. I've heard of an AVR version but can't find it. Best suggestion I've heard so far is a small CPLD or FPGA, though that means a lot of design work.
Would this website help? They seem a bit expensive but a good alternative.
http://www.organservice.com/crm/topdividers.htm
If forum members, or myself, wanted to roll their own "TOS" IC, that would be a fun learning experience. The topology of the design is quite simple actually as it is a series of redundant dividers with different feedback coefficients to provide the correct output frequency. Using an MCU's wide timers would work nicely or using a CPLD with redundant dividers would work equally well.
Usually it is desirable to output a square wave with 50% duty cycle on each of the note outputs. When designing the hardware counter method, the divider is usually decoding a specific count then resets a counter giving you 1 pulse per "N" counts. The output of such a decoder would thus not be a 50% duty cycle but some really narrow pulse equal to the period of the master clock if synchronously loadable/resettable counters are used . To get around this, using an example of the /426 output of the chip illustration, I would create a divide by 213 using the above method then then feed this to a toggle flip-flop to divide this by 2, thus a 50% duty square wave with a division of 426 would be created. I hope I did not go too far with this Very Happy
Anyway, I will dig up my EGG and take a peek at the TOS chip and post some pictures of it as well ......
Bill
 Filesize:  8.58 KB
 Viewed:  17438 Time(s)
Audio files: 25
PostPosted: Fri Jan 04, 2008 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh dude this is so funny man !!!!!!! Thanks for the humor ! Too bad you did not have pictures of this experiment of yours Very Happy
Bill
sneakthief
PostPosted: Fri Jan 04, 2008 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm not sure if that ks-87 will work as a drop-in replacement - compare that to the frequencies that the MK50240 uses:
Posted Image
in the EGG schematic, it's using the following divisions:
239
253
319
358
379
426
478
However, I think the MO83 would:
Posted Image
Audio files: 25
PostPosted: Fri Jan 04, 2008 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes. Thanks. I was siting a design example for rolling your own but YES, I appreciate this clarification very much !!!!!! Good detective work there Very Happy I hope I did not mislead anyone Embarassed
Bill
sneakthief
PostPosted: Fri Jan 04, 2008 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
btw, i found a possible source for the MK50240 for $24 US. i'll let you guys know if it goes through
ps. sorry to hijack this thread!
Audio files: 25
PostPosted: Fri Jan 04, 2008 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I took a peek at my EGG and it has an AMI S50240 installed and it's frequency table matches the Mostek device.
Your not hijacking, your adding value to the thread Very Happy Very Happy Very Happy
But lets see more DIY stuff you guys did when you were youngsters !
Bill
Audio files: 25
PostPosted: Fri Jan 04, 2008 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is my Chord EGG as it stands today and a closeup of the TOS chip from AMI used in it.
Bill
 Filesize:  459.4 KB
 Viewed:  409 Time(s)
 Filesize:  102.87 KB
 Viewed:  360 Time(s)
JovianPyx
Audio files: 237
PostPosted: Sat Jan 05, 2008 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Crystal sets (several), pentode audio preamp, #27 triode RF oscillator capable of transmitting, super-regenerative receiver (tube), game of "Nim" (also called Black Match) using relays, guitar driven UJT relaxation oscillator circuit for making weird synth sounds, transistor amplifiers. I'm sure there's more, but that was a very long time ago...
Audio files: 25
PostPosted: Sat Jan 05, 2008 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
OH yes, I had designed a UJT relaxation oscillator years ago but not to make any sound but as part of a PWM circuit in a DC motor controller to drive a radar antenna at various speeds Cool I have not used UJT's since. Thats was many years ago also. Very Happy Brought back memories from my old radar lab .......
I take it you have a radio operators license ?? The ARRL handbook was a goldmine of information. Wink I currently just have a "TECH" class license because of my amateur rocketry efforts. I was more interested in ATV and DATA transmission (telemetry) rather than the VOX stuff on 2/6 meter ......
Bill
JovianPyx
Audio files: 237
PostPosted: Sat Jan 05, 2008 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill
Sadly, I do not have a license. I was close to a Novice lic. back then, I had the code speed at the required 5+ wpm send and 7+ wpm receive. I knew the theory too, just never took the test. Got busted by the radio cops once for sending out a 60 Hz halfwave buzz on 1000 KHz. I had it on a horizontal longwire antenna that was 30 feet off the ground (normally used for crystal sets). I wanted to see how far it went as I rode my bike with a transistor radio. When I came home, there they were. They told me I didn't belong on that wavelength and that I should get a license... [sigh]. But I digress and go off thread a bit.
cappy2112
PostPosted: Sat Jan 05, 2008 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
My favorite at age 9 Very Happy Very Happy Tandy corporation ... now vintage ....
Bill
While these aren't really DIY, I grew up with Radio Shack kits too.
I had a 10-in-1, then a 50-in-1 kit. Those solderless spring terminals were great.
I still have a Radio Shack Electronics dictionary from 1974-75, and many of the Engineers Notebooks from Forrest Mims.
Does anyone remember the free battery card radio shack gave out?
I must have had one from each store in the area. But their free batteries didn't last very long Wink
I made a few P-box kits too, but I dont remember all of them.
I know I made the Vox circuit though
http://my.core.com/~sparktron/131P1.JPG
Of course there was Edmund Scientific as well. They had a neat logic trainer, but their stuff was so expensive for a kid
And then there's Paia.
Scroll down in this link to see some old Paia catalogs that I have.
http://www.electro-music.com/forum/viewtopic.php?highlight=paia&t=16195
 Filesize:  182.51 KB
 Viewed:  361 Time(s)
cappy2112
PostPosted: Sat Jan 05, 2008 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
(Rockets were so much FUN!!). Rockets meant that you spent more time in the sunshine rather than the dark. However when I got into photography, 95% of the time was spent in the darkroom anyway! Very Happy
Oh yes. Who could forget the rocket kits from Estes and what is the name of that other company?? There were two companies that I remember that sold model rocket kits when I was a kid.
I never saw my first rocket after the initial launch. The wind took it far far away. Wink
Audio files: 25
PostPosted: Sat Jan 05, 2008 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh the Mims books, yes !!! I loved them and built many of those circuits Very Happy Those old catalogs from PAiA trigger some memory cells as well. Very Happy
The other company was "Century Engineering" they made fantastic model rocket kits. There was also "Flight Systems Inc." and "Enerjet". I believe they made solid propellant motors also. "Cox" also made black powder motors and kits also.
Thanks for your posts !
Bill
Audio files: 25
PostPosted: Sat Jan 05, 2008 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh but what a cool experiment. How else to learn but to take empirical data. Cool I probably would have been just as curious as you were about how far that signal would travel. Nice .....
Bill
cappy2112
PostPosted: Sat Jan 05, 2008 7:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well that Chord egg sounds pretty neat, for a paia kit. Most of the things they made didn't sound so good.
Bill
Good thread. Thanks for starting it (while I can still remember this stuff)! Smile)
Were any of you into stamp collecting? ;-0
Former site admin
Audio files: 353
PostPosted: Sat Jan 05, 2008 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup, but the electrons moved in boring patterns Shocked
Audio files: 25
PostPosted: Sat Jan 05, 2008 8:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Audio files: 25
PostPosted: Sat Jan 05, 2008 9:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
We can thank "Liquidpaper" for that Very Happy Very Happy What a great handle that is !
Bill
Audio files: 25
PostPosted: Sat Jan 05, 2008 9:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
My Profile :
Occupation: Electrical Engineer
Interests: Electronic Music / Electronics/Electronic Design/Electronic Instrument DIY / Electronic Music & Computer History/Amateur Rocketry/Stamp Collecting
