Midi Through fun :-)
Page 1 of 1 [6 Posts]
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Mar 30, 2008 9:32 am    Post subject: Midi Through fun :-) Reply with quote  Mark this post and the followings unread
I use a MidiMan 2x2 interface and playing the NL2 I discovered a strange effect...
Attached is the factory preset sound 0001, the fist part the Midi interface is set to normal, the second part is set to Through. No parameters or buttons were touched, only the interface. What could be happening?
Wout
0001.wav
Two times 0001
 Filesize:  4.89 MB
 Duration: 0:29
 Viewed:  1694 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Mar 30, 2008 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, I found out...
Playing Slot A, which sends Midi Out on Channel 1, activates in Through mode Slot C, which happens to be also on Channel 1.
Again, all is logical!
Wout
Former site admin
Audio files: 353
PostPosted: Sun Mar 30, 2008 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wink
Nice effect BTW.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Mar 30, 2008 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is Smile
Unfortunately it's already rather late, but I think I want to try something using G2 Midi modules together with Delay modules, so I can do funny things with different Slots.
I miss a hour or so, today...
Wout
Former site admin
Audio files: 353
PostPosted: Sun Mar 30, 2008 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
All the computer clocks are wrong ...
cappy2112
PostPosted: Wed Apr 02, 2008 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout Blommers wrote:
It is Smile
Wout
I have a midi patch bay (since ~1994) which has a feature to add delays to certain midi messages. I've never found a use for the delay feature, but if you delay a note and reduce it's velocity, you could probably use it as a cheap digital delay.
