Nord Wave vs. Nord Lead 2 (sound)
Page 1 of 1 [25 Posts]
radiospace
PostPosted: Wed Apr 09, 2008 9:34 pm    Post subject: Nord Wave vs. Nord Lead 2 (sound) Reply with quote  Mark this post and the followings unread
I had a chance to try out a Nord Wave a few weeks ago and was pretty impressed. Unsurprisingly I spent the majority of the time exploring the sample-based synthesis, and didn't poke around much with the more traditional virtual subtractive synthesis.
How does the Wave compare to the Lead 2x when using it, essentially, as a Nord Lead, with traditional analog waveforms, etc.? (I don't own a Nord Lead 2 but like the sound of it quite a bit). If you get a Nord Wave are you getting every bit of the goodness of the Lead 2 sound, or are you losing a bit of the mojo there?
(Obviously this is directed at those who've owned both keyboards or have spent considerable time with them in some manner).
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Apr 09, 2008 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome radiospace
You can't compare the Wave's 'normal' synth part with the NordLead 2X, e.g. the Wave has much more routing possibilities then the NL2X. The Wave is more like the NL3. The sound is much more defined as the NL2. Why don't you download the Manual from www.clavia.se?
Wout
radiospace
PostPosted: Thu Apr 10, 2008 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout,
I understand that the Wave has a lot more to offer according to its schematics than the Lead 2X. However, many people think, for example, that the Lead2 sounds better than the Lead3, despite its limitations. It is in those terms, of the pure sound quality, when reducing the possibilities to a very simple patch, say a Saw-wave bass part, that I ask for opinions. I've already downloaded and read part of the manual, but of course it can't answer a question about how the synth actually sounds. (Thanks for the link anyway).
What did you mean by "the sound is much more defined as the NL2"?
Ruud
PostPosted: Thu Apr 10, 2008 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I played the 2X for some years and changed it for the Wave.
The Wave has real nice instrument samples to play right from the start. The fun is you can finally mix these normal sounds with the synth waves which give you totally different soundscapes.
Sometimes you just want to play a organ or a piece of violin in a number without anything else, and when you want to make it experimental you just start turning the knobs.
I think the wave has more possibilities
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 10, 2008 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
radiospace wrote:
... What did you mean by "the sound is much more defined as the NL2"?
Maybe the word 'cleaner' is a better description? In a way I think you only can answer the question yourself by playing both synths in the shop or at a friends studio... There are users who say the NordLead(1) sounds much more raw then the NordLead2
So, why souldn't we build up a small library of a simple sound? And publish it on e-m.com?
What would be the best test?
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 10, 2008 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Ruud wrote:
... I think the wave has more possibilities
Hi Ruud,
The question is about the normal wave forms (like Saw) of the Wave. Are these about the same as on the NordLead2X or not? Just because it is a very subjective matter, words are not the right instruments to make the discussion, so I suggested sound samples.
Wout
I don't own a Wave nor a NL2X. I can do the NL1, NL2, NL3, NM Cl and NM G2.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 10, 2008 3:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Here are some try-out files about the NL, NL2 and NL3
Just a single Saw wave (Mix to the left), a LPF and Amp, both with the same ADSR values.
I recorded a little bass line and a chord progression (well, progression Wink
First three bass lines...
Wout
NordLead1_SawBass.mp3
NL Saw Bass
 Filesize:  67.27 KB
 Duration: 0:09
 Viewed:  3517 Time(s)
NordLead2_SawBass.mp3
NL2 Saw Bass
 Filesize:  52.37 KB
 Duration: 0:07
 Viewed:  3656 Time(s)
NordLead3_SawBass.mp3
NL3 Saw Bass
 Filesize:  63.19 KB
 Duration: 0:08
 Viewed:  3421 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 10, 2008 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
The Same using the Unison (Which makes it a little different...)
Wout
NordLead1_SawBass_Unison.mp3
NL Saw Bass Unison
 Filesize:  66.25 KB
 Duration: 0:08
 Viewed:  3118 Time(s)
NordLead2_SawBass_Unison.mp3
NL2 Saw Bass Unison
 Filesize:  63.39 KB
 Duration: 0:08
 Viewed:  3198 Time(s)
NordLead3_SawBass_Unison.mp3
NL3 Saw Bass Unison
 Filesize:  64 KB
 Duration: 0:08
 Viewed:  3151 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 10, 2008 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
The chords...
Wout
NordLead1_SawChord.mp3
NL Saw Chords
 Filesize:  72.17 KB
 Duration: 0:09
 Viewed:  3194 Time(s)
NordLead2_SawChord.mp3
NL2 Saw Chords
 Filesize:  74.62 KB
 Duration: 0:10
 Viewed:  3227 Time(s)
NordLead3_SawChord.mp3
NL3 Saw Chords
 Filesize:  67.06 KB
 Duration: 0:09
 Viewed:  3163 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 10, 2008 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
And the chords with Unison (special to the NL3)
Wout
NordLead1_SawChord_Unison.mp3
NL Saw Chords Unison
 Filesize:  67.47 KB
 Duration: 0:09
 Viewed:  2904 Time(s)
NordLead2_SawChord_Unison.mp3
NL2 Saw Chords Unison
 Filesize:  81.55 KB
 Duration: 0:10
 Viewed:  3076 Time(s)
NordLead3_SawChord_Unison.mp3
NL3 Saw Chords Unison
 Filesize:  70.74 KB
 Duration: 0:09
 Viewed:  3057 Time(s)
radiospace
PostPosted: Thu Apr 10, 2008 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout,
Thanks for taking the time to produce all those files!
The one that is most interesting to me (because it is the most simple and straightforward) is the bass part, without unison. On the bass ones, though, it sounds to me like the filter is progressively closed down from the Lead to the Lead 2 to the Lead 3.
If you feel like it, how about posting another sample each of the 2 and the 3 bass part, but try to open the filter up more to get more sizzle like the Lead example.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 10, 2008 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
radiospace wrote:
... If you feel like it, how about posting another sample each of the 2 and the 3 bass part, but try to open the filter up more to get more sizzle like the Lead example.
After lunch... or maybe next week-end... Smile
I used the parameter value to set the LPF and ADSR's. In MHO it shows some differences in designs. So I will re-record the files and open the Filters by using my ears.
Wout
W.T.
G2 patch files: 11
PostPosted: Thu Apr 10, 2008 5:43 am    Post subject:   Reply with quote  Mark this post and the followings unread
why does the nl 1 and 3 sound dull compared to the nl2, in the last two examples. filter i gues.
great to hear the 3 nl synths next to eachother, the nl1 has the most raw edge i presume....
Ruud
PostPosted: Thu Apr 10, 2008 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
"words are not the right instruments to make the discussion"
Hi Wout,
I am not a techie but more a musician so I it's fore me more a feeling of describing a sound.
Sorry I use words for that Smile
The Wave has more to offer in the total music pallet in my opinion.
Afcourse it also depents on what style of music you like.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 10, 2008 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
But you can generate a part of the answer Smile Can you make a mp3 file of a Saw wave form? Somewhat like those I did today? Or something else, so I will make those other ones again... I don't have a Wave yet. (Just waiting until those boys will make a rack version! Thomas!!!!)
Wout
Lbsword
PostPosted: Thu Apr 10, 2008 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
It sounded to me, like with all the NL 2 sounds you posted, the filter was drastically different.
They all sound good to me, but maybe adjust the filter on the nord 2 so they all sound pretty similar. It seemed like th filter let a lot of stuff go through, compared to the 1 and 3.
Nightrider
PostPosted: Tue Apr 22, 2008 8:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow I can't believe how flat the NL3 sounds compared to the NL1/2, amazing
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Apr 23, 2008 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I don't know if it is fair to use the same values to the NL3. In the near future I will do the test again and try to get the sounds as close as possible.
At the moment a little to busy with the NL2...
Wout
PH0T0N
PostPosted: Fri Feb 05, 2010 2:14 pm    Post subject: Hate to beat a dead horse Reply with quote  Mark this post and the followings unread
Sorry to bring this thread back but geez Wout it seems as though you unlocked the secret behind the Nord Lead 2's sound!! Nords are like owning BMW's, they are all nice they just have different characteristics.
From these sound examples you can clearly hear that the Nord Lead 2 is a wonderful sounding instrument! I just bought one so I am really excited - I had to get a little of that "vintage" vibe
Studio A: Allen&Heath ZED R16 · Yamaha MSP 7's · EMU XL-1 TURBO · Nord Lead 2 w/expansion · Access Virus TI2 61 key · AppleMacBookPro 15.4" · PC w/intel q6600@3.2ghz · GTX 280 · 8gb DDR2 · Windows XP sp3 · Native Instruments Maschine · MPC 2000xl · Ableton 8/Sonar 8/Reason 4.0/FruityLoops 9/Waves Bundles/Logic 9/Phaedra/Komplete 6 *Wanted* Elektron MachineDrum SPS-1 MKII · MiniMoog Voyager Rack
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Feb 07, 2010 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Smile
Wout
Cheekyboydanny
PostPosted: Mon Feb 08, 2010 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout,
What (Software/Hardware) are you using to record your samples to mp3?
Regards
Danny
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Feb 08, 2010 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some terrible lousy crapy free software which I'm trying to forget...
Now I use Nero 9.
Why you're asking?
Wout
Cheekyboydanny
PostPosted: Mon Feb 08, 2010 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just bought an Alesis USB Mixer and Cubase came bundled with it. But Cubase looks a tad complicated to setup.
Did you just record live AUDIO from you keyboard through your free crap software or were you using midi?
Regards
Danny
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Feb 08, 2010 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I believe it was a long time ago...
Listening to it it's surely no Midi.
(Hold is different every time)
Recorded in Sound Forge and converted in a 22.1 kHz format mp3.
Sorry for that...
Wout
Cheekyboydanny
PostPosted: Mon Feb 08, 2010 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok thanks for that.
This Cubase is a right pain to setup !! Not liking it at all so far.
Regards
Danny
