Coming up on Radio 1 at
Nord Wave outputs balanced?
Page 1 of 1 [3 Posts]
bootlegtrader
PostPosted: Wed Jun 04, 2008 7:01 pm    Post subject: Nord Wave outputs balanced? Reply with quote  Mark this post and the followings unread
The manual says the outputs are line level, and to use "mono-plug connections" to other line level equipment. Should I be using balanced TRS cables, or unbalanced instrument cables? Thanks a lot.
paul
dorremifasol
G2 patch files: 49
PostPosted: Sun Jun 08, 2008 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
There should be no difference in using balanced or unbalanced cables.
Albert
bootlegtrader
PostPosted: Sat Jun 28, 2008 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, thanks. i have been using balance cables anyways.
i just remember reading either in the sherman filterbank manual or on their forum that you should use unbalanced cables for that piece of gear. in the g2x manual and on the clavia.se it said balance and line level. i was confused whether it was supposed to be understood that it was a balanced signal, or they purposely left it out...
either way balance cables seem to sound good. thanks again.
paul
