kris100990
Posted: Mon Nov 03, 2008 1:29 pm Post subject:
nl2 key split problem/banks c and d problem |
Hello I need help with my newly purchased lead 2. I just bought it a week ago and noticed that the program banks c and d aren't working. This is really inconvenient because I really want to take advantage of the key split function. What is happening?!?!?!  |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Nov 03, 2008 1:56 pm Post subject:
kris100990
Nothing to worry about
First of all A, B, C and D are Slots, not Banks. Banks are parts of the memory, while Slots are synths. In fact you have 4 synthesizers in you NordLead.
Why don't you hear Slot C and D?
Probably the Output mode is set wrong, e.g. they are send to the physical Out jack connectors C and D at the back of the synth. Do you have these connected to you mixing desk?
You can also send C and D to the physical Outs A and B.
Press [Shift+OutMode (= knob B)] You'll see the settings of Slot A and B. If it reads [1.Ab] it means they are send stereo to physical Out A and B.
Leave it that way...
Press [OutMode] again. It probably reads [1.cd] which means the situation described above. Change this by using the Up&Down buttons (probably down) in [-.cd]. This means all settings in Ab will be copied here, so the sound will go to physical Outs A and B.
Wout |
kris100990
Posted: Mon Nov 03, 2008 2:21 pm Post subject:
| ok great thanks a lot! i honestly did not know what was going on with my synth. i am new to synthesizing and stuff as you could probably tell. But is there a way that i can play both outputs with one cable? how do you use the keyboard split function? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Nov 03, 2008 3:21 pm Post subject:
First: do you have a Manual?
You can download the Lead Manuals at http://electro-music.com/forum/topic-29446.html
almost at the end of the first page.
To split the Keyboard see Manual NordLead2 - page 14...
Select a Program in Slot A (and B)
Select a Program in Slot C (and D)
Beware Slot A (B) will be played at the lower part, mostly a bass sound, and Slot C (D) at the higher part, mostly a lead sound.
Press [KBD Split] and the routing is done.
To set the lowest note of the upper keyboard, press [Shift+KBD Split] and hit the key you want to use. Release the buttons.
BTW in the Manual is written the KBD Split LED is green, although mine is red, but I can live with that
Wout |
kris100990
Posted: Mon Nov 03, 2008 3:37 pm Post subject:
ok i understand fully now. the only problem is getting both sounds out of one output. can i even do that? cuz i am getting sounds from outputs a and b which correspond to slots a and b. then im getting sounds from outputs c and d from slots c and d. is there a way to have all 4 slots sound through one output?
thanks |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Nov 03, 2008 3:44 pm Post subject:
No, not 4 sounds from one single mono output... (Which isn't true! See below)
You can direct C and D also to A and B, as I described here above.
The NordModular can do such things easily, the Lead not.
I should do this in the mixer if it has the ability to create sub groups. (It's a possibility...)
Wout Last edited by Wout Blommers on Tue Nov 04, 2008 5:04 am; edited 1 time in total |
kris100990
Posted: Mon Nov 03, 2008 7:11 pm Post subject:
| so what do you recommend for me to cope with this inconvenience? should i get a mixer? or just feed 2 cables to different speakers? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Nov 03, 2008 11:18 pm Post subject:
It depends what you want, but I have the feeling you're referring to playing on stage? If you only use one channel, you can't use the Unison right. In fact, that's the only setting when the synth is real stereo
If you want to use only one line, set the Out mode to [2.Ab] and [-.cd], using only the physical Output A. All Slots will be on that cable all together, and Unison works, only not as beautiful as in stereo (BTW the same goes for Pphysical out B)
Did I wrote it wasn't possible? Silly me...
(I never use this setting when recording)
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Nov 04, 2008 5:15 am Post subject:
| Wout Blommers wrote: | | ... All Slots will be on that cable all together, and Unison works, only not as beautiful as in stereo ... | And it is so beautiful... 4 Slots saw waves in mono Unison! You can create leads which blows your audience away!
Wout |
kris100990
Posted: Tue Nov 04, 2008 6:03 am Post subject:
THANK YOU SO MUCH. that is what i wanted in the first place.
i bought a mixer though in case i wanted to get that beautiful mono sound from it. it was a cheap $30 mixer without an eq. i figured that is all i need to really show off this beast of a synth |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Nov 04, 2008 7:16 am Post subject:
| kris100990 wrote: | | ... that beautiful mono sound from it. it was a cheap $30 mixer without an eq. i figured that is all i need to really show off this beast of a synth | 'That beautiful stereo sound, you mean Indeed, these mixers don't cost a thing, now-a-days. The cables are more expensive...
Wout |
