Kewl ChucK Song
Page 2 of 2 [39 Posts]
Goto page: Previous 1, 2
kijjaz
PostPosted: Tue Nov 04, 2008 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I have one idea for a Hi Hat, i'll try to program one in my free time.
first idea:
Stick connects to Cymbal1
(use LPFed Noise and Karplus-Strong model)
then Cymbal1 - offset for bias, then connect to HalfRect
HalfRect connect to Cymbal2 (LPFed Noise and Karplus-Strong again)
combine these signals to form the sound from the hi-hat.
then pass the signal of Cymbal1, Cymbal2 to a BPF
and automate that filter's frequency according to hi-hat's open/close state.
hmmm this is quite complex.
there should be many more parameters to play with, for example, damping of each Cymbal.
Inventor
Audio files: 270
PostPosted: Tue Nov 04, 2008 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I don't know drums that much, the only reason I asked about hi-hat is that a friend of mine listened to the music and said "don't you think you need a little hi-hat?". Maybe just a cymbal will do...
PostPosted: Tue Nov 04, 2008 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
radarsat1 wrote:
Kassen wrote:
(but it has internet streaming as well)...
url?
http://www.radiotonka.nl/
Radio Tonka started as a pirate station in the The Hague squat scene (squatting is legal here for buildings that have been unused for at least a year). The Hague has a rather unique alternative musical culture mainly around garage/blues and electro/acid with a lot of small semi-legal stages and cross fertilisation from the conservatory.
Tonka is now broadcasting legally, piggy-backing on the official "town radio" in the small hours. It has a (LONG!) history of experimental and "unexpected" music. If there are any constraints to what I can play or say at all I'm unaware of them and typically I join in the rich tradition that Tonka has of having a drink while presenting ;¬).
Aside from my regular slot every 2nd and 4th Tuesday night (so actually Wednesday morning) from 1-2am I sometimes fill in (like tonight from 12-2). In the past I already featured Les's work and Perry's anthem as well as some excerpts from performances that were published through Toplap.
The Hague is GMT+1 so that places it in the afternoon on the N.A. continent and morning in -say- Australia. Because of the local nature of the station I present my show in Dutch unless interviewing people who don't speak Dutch. I'd be happy to feature people who would have a chance to stop by or -more likely- interesting material send my way. There is 0 budget but of course I'd be happy to attribute pieces to their composer.
All in all it's not that big a deal, just a fun hobby project because I find midnight radio romantic.
radarsat1
PostPosted: Tue Nov 04, 2008 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
you'll find that drum synthesis can actually get really complicated, because percussion sounds can be very complex. Cymbals in particular tend to oscillate in very chaotic ways, not just simple modes. But the good news is that you can get away with a pretty simple (if a bit 'robotic') hihat sound by just running some noise through an enveloped high-pass filter.
(that's pretty much how the TR-808 drum machine does it)
kijjaz
PostPosted: Wed Nov 05, 2008 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Inventor: This is one of my recent idea on a Hi Hat sound.
It's quite straight forward, made from filtered / enveloped Noise.
The result is quite nice but need some more filtering to carve out the frequencies we don't need.
In there i've got a ringing sound of the cymbal, can be set by "CymbalFreq",
and also the bass sound heard when hitting a real Hi-Hat.
Now it's not easy to use,
but let's try it.
You can play by setting s.gain to velocity
and see the way i set hi hat decay in Rehit() function.
Code:
// example Electro Hi Hat sound
// - for ChucK programming language
// Copyright 2008 by Kijjasak Triyanond (kijjaz@yahoo.com)
// This software is protected by GPL version 3 license.
0.7 => float DecayRate;
3000 => float CymbalFreq; // Karplus-Strong Frequency
120 => float HiHatBassFreq;
6.5 => float HiHatBassQ;
1.1 => float HiHatBassGain;
5.5 => float HiHatNoiseGain;
.5 => float HihatLimiterThresh;
.18 => float HihatOverdrive;
// PATCHING
Noise s => Delay d => Gain d_fb => d => Dyno MASTER => SinOsc MASTER_od => dac;
d => LPF d_f => SinOsc d_f_od => MASTER;
s => Gain s_DriveGain => SinOsc s_od => MASTER;
// INITIALIZING
second => d.max;
1 => s_od.sync => d_f_od.sync;
d_f.set(HiHatBassFreq, HiHatBassQ);
HiHatBassGain => d_f.gain;
HiHatNoiseGain => s_DriveGain.gain;
second / CymbalFreq => d.delay;
1 => MASTER_od.sync;
MASTER.limit();
HihatLimiterThresh => MASTER.thresh;
HihatOverdrive => MASTER.gain;
// TEST CODE:
spork ~ Rehit();
while(true)
    s.gain() * DecayRate => s.gain;
    ms => now;
fun void Rehit()
    int i;
    while(true)
        if(i % 4 == 0) 1 => s.gain;
        else .05 => s.gain;
        Std.rand2f(.1, .99) => DecayRate; // Randomize Decay Rate
        1.0 - (1.0 / DecayRate) * (samp / ms) => d_fb.gain; // Reset Delay Feedback Value
        if (i % 16 < 8) .2::second => now;
        else .1::second => now;
        i++;
Inventor
Audio files: 270
PostPosted: Wed Nov 05, 2008 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
kijjaz,
this looks terrific and well thought out. However at the moment my schizophrenia is acting up. My mom dragged me to a psychological study of schizophrenics and it brought back a torrent of bad memories and anger toward God and all sorts of horrible feelings and in this state of mind I cannot concentrate well enough to understand your code. Give me another day or two for it to clear up, then I will look closer.
Les
kijjaz
PostPosted: Wed Nov 05, 2008 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh Les, get well soon. Are there many places to chill there?
Inventor
Audio files: 270
PostPosted: Thu Nov 06, 2008 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
There are a few, but I don't go there because the public always stares at me. They are very rude, they look at me, they gawk, then they turn away and pretend to ignore me. They seem to recognize me from tv or internet or something, but I have not been on either. I just want it to end. Maybe I need to move to a smaller town. But no, no place to relax. I just sit in front of the computer and play loud rock music on the headphones until I get better.
kijjaz
PostPosted: Thu Nov 06, 2008 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm.. how about the birds and the trees in the park?
Inventor
Audio files: 270
PostPosted: Thu Nov 06, 2008 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, there is a park nearby, but the people there would stare at me, which only serves to aggravate the condition. There is the back porch looking over the lake but i have no chair for it. So I stay inside.
I wrote a song, a very angry evil song, and slept some. That seems to have helped a good bit.
Inventor
Audio files: 270
PostPosted: Fri Nov 07, 2008 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, kijjaz my man, I had a nice long talk with my girl and slept some more and now I feel refreshed and ready to work on it. First, the hi-hat sounds terrific!
My primary concerns now are with name conflicts and calling methods. I suppose the 1::ms spinning time loop can be made into a shred, because my time loop is already occupied. but then how do I turn the rehit() function into a called routine? It needs to be called with a frequency maximum of about 1/8 of a second or so. Can we spork it and have it me.exit() after an appropriate time?
Also there will be name conflicts with some things like n and s and such being names you use in the bass drum or elsewhere. Can I just throw a class wrapper around the body and refer to everything within by class reference? Better still, can spin() and rehit() be member functions?
I really hate to reply to your excellent work with a request for a little polishing up, but I guess that is what I am doing. So how about it kij, a little cleanup work to make it a truly reusable, portable code? If you do not want to do that, I will gladly take a try at it, but you are the one who has it all active in memory so to speak...
Thanks so much, kijjaz! You brightened my week with a little hi-hat!
Inventor
Audio files: 270
PostPosted: Fri Nov 07, 2008 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried to make the changes, but all I got was a high-pitched squeal. Help kijjaz, haha!
Code:
class hi_hat_drum {
    // PATCHING
    // INITIALIZING
    second => d.max;
    MASTER.limit();
    fun void Rehit(float s_gain, float decay)
        s_gain => s.gain;
        decay => DecayRate;
    // time loop
    while(true)
        ms => now;
// Test Code
hi_hat_drum hi_hat;
while (true) {
    hi_hat.Rehit(Math.rand2f(0.05, 1.0), Std.rand2f(.1, .99));
    second / 4.0 => now;
Inventor
Audio files: 270
PostPosted: Fri Nov 07, 2008 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I have something a little more positive to report this morning. I got the idea that I could make a drumless drum set by securing the GMS prototype to a plastic stick and writing appropriate software. So far it kind of works. I have it triggering kijjaz's bass drum, though it hits extra times due to the rebounding of the stick in the stop position. Any ideas on how to fix this? Anyways, cool application eh?
Inventor
Audio files: 270
PostPosted: Fri Nov 07, 2008 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I got the drumstick program to work using kijjaz's bass drum. It plays with louder and harder drumbeats the harder you wave the stick. The recording, though not that rhythmical, illustrates the variety of tones that can be generated. Now I just need to add other drums based upon the angle of striking and then it will become a full drumset on a stick!
DMS_example.mp3
Drum example
 Filesize:  423.67 KB
 Duration: 0:27
 Viewed:  2099 Time(s)
