Where are you getting your "L" brackets to mount your PCBs?
Page 1 of 1 [12 Posts]
valis
Audio files: 6
PostPosted: Tue Feb 17, 2009 10:46 pm    Post subject: Where are you getting your "L" brackets to mount your PCBs? Reply with quote  Mark this post and the followings unread
Hello All,
I've gone around town looking for tiny "L" shaped brackets to secure my PCBs to their panels but I haven't had any luck. The problem is compounded by the fact that I'm not really sure what they're called and when I search "L shaped brackets" with Mouser and other such companies I don't get any results (or too many results).
What I want is the tiny screws and "L" bracket that you get from kits like Paia and see on many modules.I feel a tad dumb asking this question but it's something I've been searching for. Any point in the right direction would be tremendously helpful. I've been bending tiny pieces of metal and drilling a hole in it to brace my PCBs and it's a hassle.
Thanks for your time. Sorry it's such a mundane noob question..
David
e-grad
PostPosted: Wed Feb 18, 2009 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Just have ordered some at Bridechamber:
http://www.bridechamber.com/bridechamber.com/Brackets.html
BananaPlug
PostPosted: Wed Feb 18, 2009 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I think maybe it's these little Ls that Valis is looking for. Me too.
 Filesize:  29.79 KB
 Viewed:  16411 Time(s)
numbertalk
PostPosted: Wed Feb 18, 2009 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Mouser part# 534-612 (one hole threaded) or 534-621 (both threaded, 4/40).
zthee
PostPosted: Wed Feb 18, 2009 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
If you're using CGS boards you can do a frame for them. And then just attach the frame to the back of the panel. 4 screws right thru is all it needs!
Posted Image
Audio files: 19
PostPosted: Wed Feb 18, 2009 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
You could/ can also use Mecanno angle brackets Idea
 Filesize:  144.05 KB
 Viewed:  16387 Time(s)
ACHTUNG!
valis
Audio files: 6
PostPosted: Wed Feb 18, 2009 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks so much for the replies everyone. You've all been tremendously helpful. This is one of those subjects that I knew there had to be an easy solution to, yet I couldn't find it no matter how many forums I dug through. Thanks again, your posts will make my life easier..
-David
Fernando
PostPosted: Mon Jul 27, 2009 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey, the frame idea is great, similar to Serge
zthee
PostPosted: Wed Jul 29, 2009 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I've built 4 more of those now, and have to say I really like the construction. Using hinges when attaching it to the front panel makes everything very easy to handle as well. Just flip it open and wire the backside.
CJ Miller
PostPosted: Wed Jul 29, 2009 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice frames indeed!
Another standoff option is the hinged variety. I had no idea that there was any such thing until I bought an old lab circuit where the board folded out for calibration. The top two standoffs were straight, and the bottom two were hinged. I don't have part numbers but they are still made.
zthee
PostPosted: Wed Jul 29, 2009 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
The hinges can be found on mouser: http://se.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMtzcnMBgC2bs6h1FzmPjSsviG4WZyreP18%3d
ericcoleridge
PostPosted: Wed Jul 29, 2009 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, these are great. Thanks for posting this.
