Carbon111
Joined: Dec 13, 2006 Posts: 17 Location: Mukilteo, WA
Posted: Sat Mar 21, 2009 4:10 pm Post subject:
Lost Terrain - Serge Modular Explorations |
Originally this was going to be a distributed CD but I've decided to release it free on the web as MP3s as well as a lossless FLAC version: http://carbon111.com/lost_terrain.html
Lost Terrain contains three audio journeys powered by the wonderful Serge Modular Synthesizer. These pieces are composed from self-generating modular synthesizer patches with a little manually-played synth added for good measure here and there. These songs are free for personal enjoyment but are not licensed for commercial use.
Carbon111
Posted: Tue Mar 24, 2009 4:35 pm Post subject:
An overview of the elements of the pieces in Lost Terrain:
Artic-11/25
The real presentation piece in this album is Artic-11/25 as it's the most complex structurally. As an exercise, It was made with only the Serge "Creature" and "Gator" M-odules. Going into it I thought it was going to be very minimal with such a constrained palette but I was able to get a much wider selection of timbres and rhythmic motifs than I could have ever hoped.
The combination of the pulse divider and Boolean function blocks on the Gator allowed for lots of rhythmic variety even though derived from a simple pulse train - and having odd divisions as well as even ones allowed for some unexpected poly rhythms.
The Creature was the workhorse for sound generation in this pairing and I got many of the "bed" sounds, including the initial, and repeated, "rumbling drone with sonar ping" motif from this simple patch:
That was just a jumping-off point though - I added a lot of modulation from the Gator to that initial config to get those timbres.
The VCFQ turned out to be a fantastic sound source as well as being a workhorse multimode filter. The Trig input on that function block is a godsend for percussion of all types.
In Artic-11/25 there are maybe six tracks of Creature/Gator laid down.
Cenote-88
In Cenote-88, formally known as "Stumblegum" before its reworking, the Serge was used simply as a "rhythm track" accompaniment to improvised lines from an electric piano. In this piece the Serge was not multi-tracked, instead, the entire percussive section was generated from this single patch below which was tweaked with its pots through the duration of the piece to provide timbral and rhythmic changes:
Forest Area-9b
Forest Area-9b, though simpler in form both timbrally and structure-wise, used the most number of Serge function blocks. Patching on this one was much more straightforward. The melodic line that slowly builds through this piece begins as a random selection of voltages that becomes increasingly less random until about eight minutes in when the TKB is switched out of random mode and the melody becomes a repeating one.
Random pulses were used for the bird sounds and weird slow transients in the background.
A lot of long attacks on the timbres in this piece give it a weird "backwards" feel though no tracks were reversed. |
andrewF
Posted: Mon Apr 06, 2009 8:16 am Post subject:
love artic 11/25
Carbon111
Posted: Wed Apr 08, 2009 10:36 pm Post subject:
My album "Touch" is all generative modular music as well. |
