Natureboy
Posted: Mon May 25, 2009 2:57 pm Post subject:
another little problem with NL1 |
Hello i'm back again, thank you for the answer in my last question, now i dont have anymore that problem.
I noticed anyway another problem:
sometimes when I'm starting the keyboard the programs I've saved before in the Program Slots (A, B, C, D) are all reset to 1, 1, 1, 1.
What it could be?
Thank you |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon May 25, 2009 4:10 pm Post subject:
Re: another little problem with NL1 |
| Natureboy wrote: | | ... the programs I've saved before in the Program Slots (A, B, C, D) ... | You can't save into a Slot, only into a memory location. Do you also loose the sounds?
Wout |
Natureboy
Posted: Tue May 26, 2009 4:45 am Post subject:
| Wout Blommers wrote: | | Natureboy wrote: | | ... the programs I've saved before in the Program Slots (A, B, C, D) ... | You can't save into a Slot, only into a memory location. Do you also loose the sounds?
Wout |
Sorry i've explained my problem badly.
I mean when I'm playing the keyboard, I'm using for example the program n°56 on Slot A, then I set the n°68 on the Slot B, the n° 43 in Slot C and the n°10 on Slot D, when I shutdown the NL sometimes when I restart the keyboard I have the program 1 on the Slot A, the program 1 on the Slot B, the program 1 on Slot C and the program 1 on the Slot D. But this doesnt appears every time, just sometime, most of time when I restart the keyboard I have the setup I had when i've shutdown it. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue May 26, 2009 6:33 am Post subject:
| Natureboy wrote: | | ... most of time when I restart the keyboard I have the setup I had when i've shutdown it. | Which is normal.
I don't know what makes the synth switch to #1...
Maybe there is some Midi data coming in which is resetting the synth? Try it without Midi cables connected...
Wout |
Natureboy
Posted: Tue May 26, 2009 9:44 am Post subject:
| Wout Blommers wrote: | | Natureboy wrote: | | ... most of time when I restart the keyboard I have the setup I had when i've shutdown it. | Which is normal.
Wout |
I dont have any MIDI device connected. When I'm starting it an "E" appears always on the display, but just at start, maybe an error? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue May 26, 2009 2:47 pm Post subject:
No, it means the Expansion board is placed.
Wout |
hiddenthink
Joined: Aug 23, 2009 Posts: 2 Location: northwest america
Posted: Sun Aug 23, 2009 12:16 pm Post subject:
NL1 power-on issue Subject description: "E" display on power-on with no expansion. |
| Wout Blommers wrote: | No, it means the Expansion board is placed.
Wout |
Hi.
When my NL1 doesn't completely freeze upon power-up, it displays 2.6 then E, then starts up. First, Theres nothing in the dusty card slot. What's weird is it turns off MIDI control of LFO's and ruins this 1 patch that uses them. Is it a bug I've created, or did I get ripped-off on craigslist?
Thanks. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Aug 23, 2009 12:57 pm Post subject:
Re: NL1 power-on issue Subject description: "E" display on power-on with no expansion. |
hiddenthink
| hiddenthink wrote: | | When my NL1 doesn't completely freeze upon power-up, it displays 2.6 then E, then starts up. | The Lead can freeze up when it is receiving Midi data at the same moment. | Quote: | | First, Theres nothing in the dusty card slot. | Is there just a slit in the red hood or is there something in which you can insert the card in? If so, it's expanded, even when you haven't inserted a card. | Quote: | | What's weird is it turns off MIDI control of LFO's and ruins this 1 patch that uses them. | Special functions aren't saved in Program mode, only in Performance mode [See Manual page 56], which is only to be saved on a PCMCIA card, which, I believe, isn't inserted. So, no strange behavior. | Quote: | | Is it a bug I've created, or did I get ripped-off on craigslist? | This I can't tell you, if you are ripped-off. It's up to you to decide this. I am only trying to help you with some of the disappointments and frustrations: you expected something and until now this isn't there yet!
Wout |
hiddenthink
Posted: Sun Aug 23, 2009 5:05 pm Post subject:
Re: NL1 power-on issue [SOLVED] Subject description: "E" display on power-on with no expansion. |
| WoutBlommers wrote: | The Lead can freeze up when it is receiving Midi data at the same moment.
Thank You - it is no longer freezing at power-up.
| WoutBlommers wrote: | Is there just a slit in the red hood or is there something in which you can insert the card in? If so, it's expanded, even when you haven't inserted a card.
Just a (empty) slit in the case labeled: PCMCIA slot.
I assume all I need is one of those little cards, and not some special expansion case to hold a card.
I still displays 2.6 then E on startup. I swear it didn't do that before.
This is an amazing machine. I can't wait to find a card and some new pots for it.
Thanks for the help WoutBlommers! |
