Posted: Sun Jun 07, 2009 9:16 pm Post subject:
3 Channel gatewidth Modulator Subject description: name changed added schematic
I redesigned my Lunetta-esque pulsewidth modulator circuit into something a bit beefier, easier to control and a heck of a lot more fun to play with!
I've been troubled for a while now getting good pulsewidth modulation out of the 40106 chip and I've found the solution today by using FETS over NPN/PNPs.
The controls for the PWM are as follows:
CV input and manual frequency control for each channel
Input for each channel
Output and non inverted output for each channel with LED indicator
It's finished now and I'm going to be working on the PCB/schem as well as a new scope/audio demo this week.
To make this thread worthy I've included an audio clip. The input signal is running through a frequency divider whose /2 /4 /8 outputs are running into each channel. I'm using one triangle or noise output from my triple Modulation source (think CGS Pyscho LFO but CVable and insane) to control the PW. The PWM outputs are mixed together at different levels through an external mixer. The levels sound like they're being faded in and out but thats just due to the width of the signal being hardly audible.
SM_002_PWM.mp3
Filesize:
2.68 MB
Duration:
2:56
Viewed:
1777 Time(s)
Filesize:
119.42 KB
Viewed:
770 Time(s)
It accepts just about any input signal. Works splendidly for gate signals and low frequencies, not so good with mid-high frequencies. _________________ Youtube! modular demos! Whacky tunes!
so you are using a FET to creat a variable resistance!? great.
thanks for sharing. i almost missed it
Yep! It works better than any PNP/NPN combo. I tried it with a few other circuits. One of them was the Resonator. I replaced the vactrols with two Fets and it worked kind of ok. I think my use of 4007's instead of the vactrols worked better. _________________ Youtube! modular demos! Whacky tunes!
You can change the polarity of the width modulation by tieing the 1M resistor and fet D to ground instead of V+ which would do this also, but thats what the inverted output is for _________________ Youtube! modular demos! Whacky tunes!
