Floyd Pepper
Posted: Wed Aug 26, 2009 11:49 am Post subject:
Analogue Systems or Doepfer as 1st Modular system? |
After considering getting into modulars for a several years I'm (again) thinking of pulling the trigger...
I'm based in the UK and Analogue Systems and Doepfer both seem good places to start. Their basic systems (AS System 1 and Deopfer BS 1) seem to include what I'd want to start off with. I also want to avoid spending more than £1,500 if possible.
There's not much in this forum about AS. How do people rate them? The Sound on Sound reviews seem to prefer them to Doepfer.
Should I go AS or Doepfer or mix match modules? |
abstraktor
Joined: Apr 27, 2009 Posts: 190 Location: glasgow, scotland
Posted: Thu Aug 27, 2009 4:15 am Post subject:
I have an A-sys modular system, with 2 of the A-sys cases/psu's. Although I have 3 Doepfer modules in this 9U system, the rest is A-Sys.
Yes, there's not much mention of A-Sys stuff here, apart from the Rs-95 VCO, which seems to generally well regarded. IMHO the build quality of the A-Sys stuff is better than Doepfer (but with a slightly higher price to match). Doepfer have a wider range of modules than A-Sys, but I'm perfectly happy with the A-Sys modules - very precise and very capable of big complex sounds, as well as bread and butter basses and leads. If I expand the system , I would probably go for other Eurorack modules makes (not necessarily Doepfer) that were a bit more esoteric -but that's because the A-Sys system is a fine springboard into weirdness.
Doepfer make a budget case, but be careful with wanting to use A-Sys modules in it, because the power polarity connections are reversed. My Doepfer modules have reversed leads plugged in to the A-Sys case -they work fine, but the spacing of the panels is slightly out from the A-Sys holes.
I've attached a pdf of my system, which is from the java planner
 Download (listen) |
| Filename: |
Modulo Java Image.pdf |
1.29 MB |
| Downloaded: |
735 Time(s) |
a100user
Posted: Thu Aug 27, 2009 9:16 am Post subject:
Have have a large collection of Doepfer and a reasonable number of Analogue Systems modules. My thoughts are:
Doepfer - cheaper, so hence more modules for your money hence more functionality.
A Sys - larger format modules hence less modules, better build quality, VCO's sound better, multimode filter sounds better than A121.
Personally I would go for a mix of modules. Be careful when it comes to power distribution as A Sys have their own way of doing things, where as the Euro community have all followed Doepfer's lead.
What sort of thing are you hoping to do with the synth, processing external sound, noise machine, traditional synth sounds? |
Floyd Pepper
Posted: Thu Aug 27, 2009 9:43 am Post subject:
Thanks for the replies.
I'd been considering the power supply issue and this had had me thinking if I have a few AS modules I may as well get an AS case and if I have an AS case in a small system I may as well go completely AS. From what I saw the AS modules also seemed to be better specified so I was swinging in the AS direction.
Why I want a modular for is a very good question I'm a guitar player who messes about with synths. I had several hardware synths which I recently sold. I kept the Waldorf Pulse+ as it sounds great. I was going to use the Waldorf's CV/Gate out to control the modular.
I want a modular to see what I'm missing. I'd want to use it as a synth, as a sound processor and to make beepy noises. Having looked at what modules I'd ideally have the cost would be about £3,000. At this stage I need to keep closer to the £1,500 mark. |
a100user
Posted: Thu Aug 27, 2009 11:12 pm Post subject:
All I can say is that what ever you choose it's the start of a slippery slope
Good luck with whatever you decide. |
Floyd Pepper
Posted: Sat Aug 29, 2009 2:08 am Post subject:
| Quote: | | All I can say is that what ever you choose it's the start of a slippery slope |
That's one reason why I've put modulars off for so long  |
abstraktor
Posted: Sat Aug 29, 2009 3:27 am Post subject:
Go for it Floyd!  |
Pfurmel
Posted: Mon Mar 22, 2010 1:46 am Post subject:
Hi all, Im new here and seeing as there is already a lot of My first modular threads, I thought Id just jump in here as my requirements are very similar to the OPs.
One question, abstraktor, you mentioned that you would go for some of the more esoteric euro rack gear, could you give me some examples of these? I am very much into self-evolving pads, I would be hoping to build a nice noise machine for myself and anything esoteric or out of the ordinary would be a plus. |
abstraktor
Posted: Mon Mar 22, 2010 2:37 am Post subject:
Hi
euro modulars arent too good at polyphonic pads, because theyre essentially monophonic beasts. You can tune individual VCO's to a chord, but this limits the ability to create more interesting timbres from them (for example, sync sweeps). A lot of users investigate FM synthesis (using VCO's to cross modulate each other), and this where some of the more esoteric sound generating modules aim themselves (Livewire etc.). Waveshapers can also give interesting variations on the standard saw/square/triangle wave - both of these (FM, Waveshaper modules) can produce weird and wonderful noises.
Basically though, the more VCO's, filters and envelope generators you have in a system, the more potential you have for evolving complex sounds.
I'm sure there are other users out there in E-M who can give you the low down on their specific "boutique" modules.
hope this helps  |
Pfurmel
Posted: Tue Mar 23, 2010 2:02 am Post subject:
Cool,
Well the only reason I was edging towards Euro was that most euro modules seem to be readily available over on this side of the world, if I need to buy from America for example, I am looking at import duty, which can be high in Ireland meaning I get less for my money. But if it means I get the sound I desire, then maybe its the only way to go.
Anyway, yes the Livewire modules look really interesting, especially their Dalek Modulator:
http://www.livewire-synthesizers.com/forums.html?op=modulators&module=dalek
And Cyndustries Zeroscillator looks good. Anyone around here use any of these? |
nerdware
Posted: Tue Mar 23, 2010 6:00 am Post subject:
Postmodular are in the UK and stock many of the popular Eurorack modules. There's also a Doepfer distributer in the UK. _________________ http://soundcloud.com/nerdware/
"render unto digital what is due to digital, render unto analogue what is due to analogue" |
matrix
Posted: Tue Mar 23, 2010 8:33 am Post subject:
Get a case that supports both. http://monorocket.com/ for example. Really nice cases, affordable and they support both Analogue Systems and Doepfer formats in the same case. _________________ cheers,
matrix
http://www.matrixsynth.com |
abstraktor
Posted: Wed Mar 24, 2010 10:10 am Post subject:
yep, there is much more choice available in Eurorack modules -a lot of small companies making peculiar gizmos. It's a very good time to be getting into modularity!
be sure and check power supply requirements for whatever you decide to put together, though. |
matrix
demi
Posted: Wed Apr 28, 2010 8:30 am Post subject:
MODCAN & DOEPFER POLARITY connection issues..? or not!! |
| abstraktor wrote: | I have an A-sys modular system, with 2 of the A-sys cases/psu's. Although I have 3 Doepfer modules in this 9U system, the rest is A-Sys.
I've attached a pdf of my system, which is from the java planner |
another newbie here and relative novice but been a fascinating (not timewasting) experience trawling through this very helpful and informative forum.
My question is based on the similar topic but was curious if anybody could comment on whether combining Doepfer and MODCAN modules could pose similar problems or indeed with the A-SYS - I'm in two minds still as to whether to jump on board A-sys or Doepfer |
hesed
Posted: Sat May 08, 2010 2:50 am Post subject:
I remember 5 years agoo when i bought my first modular system was a AS, after scwitching on no light was on and no sound so i send it back, after a week i receive another one and this this start to make a grey smoke.
So i decide to get a Doepfer and i had no problem. Maybe was just unfortunate or the people from the store did not plug the modules on the bus properly. That's my experience. _________________ LABEL: Analog Tecnè Model
STUDIO: Discrete Audio Solutions |
amsonx
Joined: Jan 20, 2009 Posts: 7 Location: santiago de compostela spain
Posted: Mon Jun 07, 2010 3:47 am Post subject:
| atm23.net wrote: | I remember 5 years agoo when i bought my first modular system was a AS, after scwitching on no light was on and no sound so i send it back, after a week i receive another one and this this start to make a grey smoke.
So i decide to get a Doepfer and i had no problem. Maybe was just unfortunate or the people from the store did not plug the modules on the bus properly. That's my experience. |
bad experience...
may be the problem was the not prpopery standard power conncetor of AS ?
on muff there is a useful trhead about this topic
http://www.muffwiggler.com/forum/topic-15109.html
and give a look to Makenoise modules..
hope this help |
