Coming up on Radio 1 at
Digital Noise... speed/cv pot
Page 1 of 1 [6 Posts]
fluxmonkey
PostPosted: Thu Mar 18, 2010 7:09 am    Post subject: Digital Noise... speed/cv pot Reply with quote  Mark this post and the followings unread
would there be any issue with changing the 25k speed/cv pot from 25k to 50k? i'm thinking it's just a divider, and buffered at that, but just wanted to check.
i want to add a range control, by being able to switch in/out a different timing cap on the PLL using a push/pull switch on the pot, and i can't find 25k switching pots....
b
www.fluxmonkey.com
The Peasant
PostPosted: Thu Mar 18, 2010 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
It looks like it should work fine to me. At worst the response slope of the pot would be slightly different, probably not even noticeable.
Take care,
Doug
The Electronic Peasant
www.electronicpeasant.com
Adam-V
PostPosted: Thu Mar 18, 2010 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used a 50k pot on mine and it didn't cause me any issues.
It is a brilliant noise source by the way!
Adam-V
fluxmonkey
PostPosted: Thu Mar 18, 2010 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Adam-V
agreed... even more with the cap mod, it becomes a wonderful correlated-random pulse source.
thanks for the double-check, gents, i will plunge ahead!
b
www.fluxmonkey.com
The Peasant
PostPosted: Thu Mar 18, 2010 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
What size of timing cap are you using for the second one?
Take care,
Doug
fluxmonkey
PostPosted: Thu Mar 18, 2010 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
for the slowest speed, up to 1uf...
www.fluxmonkey.com
