Coming up on Radio 1 at
Nord Rack 2X doesnt send automation to Cubase Midi channel
Page 1 of 1 [10 Posts]
nordstd
PostPosted: Sat Nov 13, 2010 5:21 am    Post subject: Nord Rack 2X doesnt send automation to Cubase Midi channel
Subject description: How can i "Write and Read" to Cubase my automations ?
Hi all Smile
My nord Rack2x doesnt send the knob movements automation to Cubase Midi channel.
What am i doing is;
1-All the connections done ( midi and audio)
2-I create Midi device on Cubase 5 and add the XML file of the Nord rack 2x and after make correct settings for add external instrument.
3-I create a midi instrument (External nord rack2x) from vst instrument menu.
Now;
I can record my midi's coming from nord rack2x and play back the presets,banks everything fine.
I can change the knob movements from my nords panel and hear the changed sounds like filter and see from the device panel it is working.But i CANNOT write and read or record the automation from my nord rack2x front panel.
I set the "local on" because it is not working with "local off" mode. it disable the knobs.
What can i do know ? is there something i miss like global midi channel setting or send knob settings for to record or anything else ?
How can i send knob movements when i am on write mode on Cubase ?
Thank you.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Nov 13, 2010 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome nordstd
Have you tried Midi Global 16 allready?
Wout
nordstd
PostPosted: Sat Nov 13, 2010 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout Blommers wrote:
welcome nordstd
Wout
Thank you Wout
No not yet , What is for "Global Midi channel 16" ?
Is this a problem for sending CC messages ?
And can you explain more ,
Thank you.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Nov 13, 2010 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Midi Global is an old fashion way to handle Midi info, special SysEx.
On the other hand CuBase has also a SysEx filter, which has to be set to disabled.
Wout
nordstd
PostPosted: Sat Nov 13, 2010 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout
So;
1- Set global midi channel to 16 , different from midi channel 1.
2-Disable Cubase SysEx filter.
Ok i will try and write here soon...
Thank you Wout.
synthetic242
PostPosted: Tue Jan 11, 2011 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I have similar/other problem.
I load Nordlead2.xml in Devices and can record param-values from Cubase.
But it seems only be possible to that on one part (slot-1 which is on channel 1).
Is it possible to record on other channel and slot?
Today: Access Virus KC, powercore virus, dw6000
Old: http://erha.se/~ronny/stuff.html
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Jan 11, 2011 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Press Slot button B and when it's Midi channel is e.g. 12 it will be recorded on channel 12.
Wout
synthetic242
PostPosted: Thu Jan 13, 2011 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout
Well, that's the opposite what I'm looking for. I want to control other slot than Slot-1 from Cubase. It seems that Devices only runs on midi channel 1.
It's not enough to open 2nd track (which is playing Slot-2) and moving slides in Devices, it will record movement on track1 (which is Slot-1).
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jan 13, 2011 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, it is more a CuBase problem than a Lead problem then?
Maybe the magic trick works...
Go to [Shift+2xMidi], which opens Global Midi and set the channel to 16.
Let me know if it works or not...
Wout
synthetic242
PostPosted: Sun Jan 16, 2011 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
My nord has already Global set to 16.
In Cubase all automation is only send on channel 1, cannot send to other slot than 1.
