Coming up on Radio 1 at
Let's see your Lunetta!
Page 12 of 22 [526 Posts]
Goto page: Previous 1, 2, 3, ..., 10, 11, 12, 13, 14, ..., 20, 21, 22 Next
sndbyte
PostPosted: Fri Oct 08, 2010 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've started working on my expansion board. I filled in 6 of the 9 spaces on the board. Now I just need to figure out the final 3 and then mount it.
They are:
CD4024: 7 stage divider
CD4060 14 stage divider
CD4017 sequencer (with a fancy bar graph for lights!)
6 patching strips with LED
CD4046 VCO
and finally at the bottom a de-bounced toggle flip flop swtich using a CD4001 and CD4013. The CD4001 is used to debounce the CD4013 flip flop.
 Filesize:  178.52 KB
 Viewed:  690 Time(s)
 Filesize:  135.57 KB
 Viewed:  718 Time(s)
tjookum
Audio files: 26
PostPosted: Sat Oct 09, 2010 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy very nice. Im super impressed with your perfboard skills, I know it is very hard to make sense of all the little jumpers. Well done, now go record something, I want to hear this thing in action!
Hunter S. Thompson
movies
noise
sndbyte
PostPosted: Sat Oct 09, 2010 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I can't wait to get this thing finished up and mounted with my other board. I've just been testing it out with the 3 piezo disks I have. The soft clicking sounds can become pretty hypnotic.
sndbyte
PostPosted: Fri Oct 15, 2010 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just finished my expansion board today so my Lunetta is complete. Here is a scan of my working notes. There are 9 new modules on the right side expansion board. I added 2 VCOs, some dividers, a flip flop switch, a binary switch and another XOR gate. I'll post a photo of it later.
(sorry the scan is kind of dark and a bit hard to read)
 Filesize:  2.01 MB
 Viewed:  907 Time(s)
sndbyte
PostPosted: Fri Oct 15, 2010 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a slightly blurry photo of the finished product.
Here are what the knobs control:
osc 1
osc 2
vco 1
lfo 1
lfo 2
voltage starve
mid range osc 1
mid range osc 2
mid range osc 3
mixer volume 1
mixer volume 2
mixer volume 3
main volume
wsg filter resonance
wsg filter cut off
And the 3 wires you see hook up to piezo buzzers so you can listen to any output without an amp or headphones.
 Filesize:  535.98 KB
 Viewed:  904 Time(s)
Audio files: 266
PostPosted: Sat Oct 16, 2010 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool looking rig. Very Happy
textual
PostPosted: Sat Oct 16, 2010 9:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
my synth so far so far. Been working on this since February. Gone through many metamorphose. Essentially all CMOS 4000 chips accept for some op amps used in the mixer and square wave shapers. I am diligently working on finishing this beast before years end.
 Filesize:  910.65 KB
 Viewed:  702 Time(s)
______________________
www.dlbelectronics.com
www.textualmusic.com
www.mercuryprogram.com
stolenfat
PostPosted: Mon Oct 18, 2010 12:14 am    Post subject: Reply with quote  Mark this post and the followings unread
wow textual!! whats with those cool circles? How did you drill your holes so straight? Very Happy
-minus-
PostPosted: Mon Oct 18, 2010 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Looking really great textual! Nice to see a machine which has been treated with 'modular' respect. Banana jacks have become a rare sight these days. It's what has been holding mine up for some time... among other things!
Thanks for the inspirational image! I shall have to get back to the logic synth stuff as soon as my drone synth is finished!
Nice build!! Very Happy
slacker
PostPosted: Mon Oct 18, 2010 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
amazing stuff, looks better than my synth let alone my Lunetta.
textual
PostPosted: Tue Oct 19, 2010 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah I do like options! The round rows of jacks are 2 straight up 4040 dividers blue jacks are clocks. I just used a compass to draw the circles and figured 12 points around it. If you look really close none of the modules are perfect i cut them all with table saw or jigsaw, sometimes they get wonky, or a hole will be off due to a bad punch, but hey! its DIY man!
I have come into a lot of time lately and am really working to complete it.
textual
PostPosted: Tue Oct 19, 2010 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I highly recommend using a punch with a hammer before drilling. Bit will never slip away from its mark whilst sitting in the punch. A drill press is a plus and very handy. You could find one on craigslist for cheap.
sndbyte
PostPosted: Sun Nov 14, 2010 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just finished a small portable lunetta. It is 6 chips on a small PC Board in a wooden box I found at a craft store.
Here is a breakdown of what you see on the board (starting from the top left hand corner):
3 patching strips with LEDs
CD40106 with 3 oscillators (1 low, 1 mid, 1 high)
CD4040 divider
CD4051 binary switch
7805 voltage regulator
small piezo buzzer
a on/off switch
CD4011 NAND gate
CD4070 XOR gate
CD4051 shift register
another small peizo buzzer
2 4-hole headers that connect to the 2 piezo buzzers you can see and the 4 piezo discs mounted below the PCB.
The 9 volt battery is below the control panel.
mini lunetta open
mini lunetta open (patched)
mini lunetta pcb
mini lunetta patched close up
textual
PostPosted: Sun Nov 14, 2010 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
way dope!
Audio files: 266
PostPosted: Sun Nov 14, 2010 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Text and Snd: great looking and well thought out designs. I'm looking forward to hearing future music. thumb up
chutneyfarmer
PostPosted: Sun Nov 14, 2010 3:04 pm    Post subject: WOW!!! Reply with quote  Mark this post and the followings unread
CD4040 divider
small piezo buzzer
a on/off switch
CD4011 NAND gate
CD4070 XOR gate
mini lunetta open
mini lunetta pcb
That is beautiful looking! Brilliant work. How do the Piezos work out soundwise? Are they pretty lo-fi or do they do surprisingly well?
sndbyte
PostPosted: Sun Nov 14, 2010 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the kind words.
The piezo buzzers were sort of an experiment for me (the 2 round plastic cased ones you see on the board). One of them is really quiet... you can barely hear it. But that is good in a way, I sit at my desk and use that quiet piezo buzzer but it is not loud enough to drive my wife crazy. The other buzzer is very loud but very lo-fi. It has a sort 'plasticy' sound due to the plastic it is cased in.
The 4 piezo discs are mounted under the board. Each is attached to the wood bottom of the box with double sided tape. They have a nice sound and are great for clicking patterns as they ping the wooden box. Each has a slightly different sound as I used a variety of different discs.
I did not put an output jack on this.
rich decibels
PostPosted: Tue Nov 16, 2010 9:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm a bit sheepish about posting this after seeing sndbyte's incredible work but here is my first 'finished' lunetta. (Finished as in it's in a box and works every time you switch it on. Not as in complete.) The case is an old PA amp. Top left is a 4093: 4 gates and 4 oscillator outputs. Below that is a 40106 with 4 oscillators with different ranges. Next along is a 4040 with an input and the frist 3 outputs (1/2, 1/4, 1/Cool, then the 8 green knobs are for a 4051-based tone sequencer. Beneath them are 2 XNORs (4077). Then on the right is a 4069 filter with just the LP output and a 4-input mixer.
As you can see it is pretty minimal and I think my next build will go down the perfboard + header pins track with many more chips but I'm pretty happy with what this little guy can do already. I made a little video. FYI the patch is attached below too.
 Filesize:  25.9 KB
 Viewed:  38675 Time(s)
 Filesize:  58.36 KB
 Viewed:  407 Time(s)
sndbyte
PostPosted: Tue Nov 16, 2010 10:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a pretty nice looking panel (and it looks much more solid and sturdy than a perf board layout). Are you going to build a box around the panel?
One thing to point out about the perf board layout style is that the ICs and header pins ultimately start to get dusty if you don't have a cover for it. That is one reason why I built my second one in a box. Also a few of the metal header pins I've used start to feel a bit loose so I don't always get a good connection. That seems to happen mostly with the pins at the end of a strip.
Keep up the good work!
rich decibels
PostPosted: Wed Nov 17, 2010 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
It's actually a box already, it just so happens that you can't see it from the camera angles in the video or the photo. What looks like a panel is actually the top of an old amp enclosure. All the knobs and jacks are mounted to the top of the old amp box, along with a long right-angle bracket that holds all the circuits. It is really sturdy but 80% of the building effort and expense goes to wiring up jacks and pots, which would be so much easier and cheaper with headers and trimmers on perfboard. Also the circuit topologies I have in mind involve about 10x as many inputs and outputs as this so I will need a more compact and cost-effective solution.
sndbyte
PostPosted: Sat Nov 20, 2010 11:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I shot 2 short videos on my portable lunetta. Sorry the video quality is so poor... I used a 6 year old digital camera.
Anyhow, this is the CD4051 binary switch in action. I'm using CD40106 oscillators (red leds) as both a clock and data on the CD4015 shift register. 3 of the shift register outputs (green leds) are patched into the CD4051 inputs. This is a binary input that tells the CD4051 which of the 8 outputs it should select as an output. The 3rd CD40106 oscillator is input into the CD4051 and ultimately routed to the one of the 8 outputs on the chip (you'll see the white leds dancing around).
The two videos give you an idea of the sort of slow and fast patterns you can generate. I am only adjusting the clock oscillator in the videos. The difference between the 2 videos is that in one video the oscillator input routed through the CD4051 is tuned higher.
The sound you hear are the 5 piezo discs I have mounted on the box.
More precise control over the patterns could be had if you used 3 low frequency oscillators as your input into the CD4051 rather than the shift register.
tjookum
Audio files: 26
PostPosted: Sun Nov 21, 2010 3:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff sndbyte!
The shiftregister/divider to multiplexer is one of the most powerfull tools in making lunetta patches, I rarely make a patch without one. One thing you could try is also using a 2x4 bit multiplexer(4052) they work really well with the 4015 and give some really nice variations.
And those piezo's don't sound bad at all, a little more "real" and organic then the usual bleeps and bloops coming from a speaker, well done!
Hunter S. Thompson
movies
noise
Audio files: 266
PostPosted: Sun Nov 21, 2010 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
... well done!
Yes, I agree. Very Happy
droffset
PostPosted: Wed Dec 08, 2010 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you like sequencers that can interact with your Lunetta, Here's something for you. Smile
The first half is quite basic information but the more involved stuff happens after that.
Edit: Spelling mistakes.
textual
PostPosted: Wed Dec 08, 2010 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
very cool! love the backwards feature.. you have a schematic yet?
