Coming up on Radio 1 at
load and dump sys-ex.
Page 1 of 1 [20 Posts]
skyz
PostPosted: Fri Nov 05, 2010 7:58 pm    Post subject: load and dump sys-ex.
Subject description: Sysex on a MAC
HI
am having alittle trouble understanding SYsex data load and dump.
i use a mac with ableton and have a nord lead 3 rack...
Ableton doesnt deal with sysex data tho!!!
what do you all use on a mac to load and dump sys-ex. files
back up presets and updates???
sorry iv sound stupid! just cant get my head around in yet
cheer for any help
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Nov 06, 2010 12:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not on a Mac, but I heard good critics about this one: http://www.snoize.com/SysExLibrarian/docs.html
Download able at http://www.snoize.com/SysExLibrarian/docs.html
Wout
skyz
PostPosted: Sat Nov 06, 2010 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for you help!..
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Nov 06, 2010 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Could be helpfull if you write back about sucses or failure?
Wout
gplusr
PostPosted: Fri Mar 18, 2011 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I bought new NL2X two days ago. I was able to receive patches using Nord Generator but I was not able to upload them to the NL2X. I saw on a small LCD that I am receiving files but all patches were distorted. Maybe some of you know why? After a few hours I have decided to use above program for the mac OSX and everything went ok from the first try Smile, so Yes it is working with our equipment Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Mar 18, 2011 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome gplusr and thanks
Strange NordGen couldn't send the SysEx. You used a Windows machine?
There is a bug concerning the MidiIn and MidiOut menu options. When MidiIn is set MidiOut will step to another Midi port.
Wout
gplusr
PostPosted: Fri Mar 18, 2011 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Smile Yes, I tried with xp sp2 and native instruments audio 8 soundcard. I used this card also on mac. While I was sending sysex to nord I could see that nord is receiving it but all knobs/setting were in the same position. I tried all setting with midi channels on xp but with no luck.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Mar 18, 2011 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some questions…
How did you detect there was Midi send to the synth?
Which SysEx files were used?
Any routing (LEDs on the Panel) changed?
Was the sound changed in any way?
What was distorted?
Knobs don’t change when uploading a new Program into the synth, only the LEDs.
Wout
gplusr
PostPosted: Fri Mar 18, 2011 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I could see on the LED for example A.Pr.
I used SysEx file from there http://nm-archives.electro-music.com/020_NordLead2/
Nothing change on the panel and as you described the sound was changed but this sound does not sound as a good patch/new instrument. I will make some movie when I find some free to time to show you how I did it.
I could also notice that the led didnt change, they were in exacly the same position as before so maybe not all data was transfered? Is it possible? Maye I should change the speed somewhere like in COM ports. It is not a big problem for me because it is working on Mac but maybe someone know the solution.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Mar 19, 2011 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you point out in the video which LED you mean? There is some confusion about this…
Most of this data is set on MidiGlobal channel 16, but this will not result in distortion…
Nothing change on the panel and as you described the sound was changed but this sound does not sound as a good patch/new instrument. I will make some movie when I find some free to time to show you how I did it. I could also notice that the led didnt change, they were in exacly the same position as before so maybe not all data was transfered? Is it possible?
If the LEDs don’t change there was no upload
... It is not a big problem for me because it is working on Mac but maybe someone know the solution.
That’s what I want to find out Smile
Wout
gplusr
PostPosted: Sat Mar 19, 2011 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Below you will find the link to the youtube.
1. I choose RESO SWEEP 004.syx
2. I drag the file to the Nord Generator
3. I choose SysEX -> Send
On the Nord
1. I could see that DISPLAY shows A.PR1 for one second.
2. I can hear that the Sound change
3. I dont see that any of the LED changed
4. The sound is not what it meant to be even when I store it in to the memory of Nord.
http://www.youtube.com/watch?v=m8dCSORvcTI
When I do this on mac, everything works fine.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Mar 19, 2011 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
What I think doesn't look right is the LED of the Pulse wave form doesn't change. It should have gone to Saw... Shocked
But surely I hear the Reso Sweep.
The indication [A.pr1] could be a feature of the NL2X, because I only own a NR original and a NL2. So this feature is new to me. (A third Lead is probably an overkill in my studio Smile)
Gladly you can work with the synth, but it's still puzzling you and me.
In two weeks I'll meet up with Clavia and will ask them.
Wout
gplusr
PostPosted: Sat Mar 19, 2011 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
That is exacly what I want to say. It sounds like it but it is not, I get completly different sound using SysEx on Mac. Thank you Wout Very Happy
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Mar 19, 2011 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
What?
This will be history!
Wout
gplusr
PostPosted: Sat Mar 19, 2011 9:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Below you will find the difference
RESO SWEEP 004 NordGen X{.MP3
RESO SWEEP 004 sent using NordGen on Win XP
 Filesize:  258.53 KB
 Duration: 0:13
 Viewed:  757 Time(s)
gplusr
PostPosted: Sat Mar 19, 2011 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
And RESO SWEEP 004 on Mac
RESO SWEEP 004 SysEx Mac.MP3
RESO SWEEP 004 uploaded on MAC using SysEx Librarian
 Filesize:  321.23 KB
 Duration: 0:16
 Viewed:  780 Time(s)
gplusr
PostPosted: Sat Mar 19, 2011 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Original file
RESO SWEEP 004.syx
 Filename:  RESO SWEEP 004.syx
 Filesize:  139 Bytes
 Downloaded:  279 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Mar 19, 2011 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can you upload the SysEx from the synth?
Yes, you can...
Can you do the following:
1. Send by Windows into the synth and downloaded from the synth.
2. Send by Mac into the synth and downloaded from the synth.
I weant to make a read out of the SysEx. There has to be something changed in the data...
Wout
PS no hurry Smile
gplusr
PostPosted: Mon Mar 21, 2011 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Below you will find two files which I have SEND from synth to mac.
First file is a file which I have DOWNLOADED to synth using win xp
Second file is a file which I have DOWNLOADED to synth using mac.
sweep 004 mac.syx
 Filename:  sweep 004 mac.syx
 Filesize:  139 Bytes
 Downloaded:  306 Time(s)
sweep 004 xp.syx
 Filename:  sweep 004 xp.syx
 Filesize:  139 Bytes
 Downloaded:  285 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Mar 21, 2011 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are some results…
Two read outs of your files. As you can see the end doesn’t contain any data. Compared with the last read out (NordGen received) the blue colored data is the routing, which means the buttons and LED’s.
SysEx down loaded from the internet or already on my computer are exactly the same.
I also think the Synth is alright. For some reason the Windows machine doesn’t take the last line of the SysEx: the routing. Some Midi cables? Too much speed? Hard to tell from here…
Read Out
 Filesize:  486.83 KB
 Viewed:  321 Time(s)
