Coming up on Radio 1 at
VCS fall/rise rate knob range
Page 1 of 1 [15 Posts]
roman_f
PostPosted: Thu Dec 29, 2011 7:13 pm    Post subject: VCS fall/rise rate knob range
Subject description: why so short
is that normal that my VCS rise/fall rate knobs operate only in a small range?
say 5-7 on the dial makes the whole knob movement
thanks
roman
Mongo1
PostPosted: Sun Jan 01, 2012 11:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
That doesn't seem right.
I've built the DUSG, which is similar, and it's knobs operate over a very wide range. It sounds like there must be something wrong somewhere.
Gary
roman_f
PostPosted: Thu Jan 05, 2012 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
please take a look at the scan of the pcb, maybe i did some mistake...
 Filesize:  167.33 KB
 Viewed:  492 Time(s)
Mongo1
PostPosted: Thu Jan 05, 2012 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Roman,
I don't know much about this one. I went over the CGS Support Group on Yahoo and asked for help over there. Maybe someone will drop by that knows more than I do about this.
Gary
janvanvolt
PostPosted: Thu Jan 05, 2012 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Will also look into this, however i have the original VCS.
One first question: Which Pots do you use ? Lin / Log ?
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
roman_f
PostPosted: Thu Jan 05, 2012 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
many thanks, gary :)
A10K on rise/fall rate
and B50K on rise/fall cv
The Bad Producer
PostPosted: Thu Jan 05, 2012 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
In the pic you posted there is a wire link missing between the FCW and SWF pads (top rightish area on board), I can't see my boards, I think this is for power to the TL074... But I guess you've already soldered that in maybe?
roman_f
PostPosted: Thu Jan 05, 2012 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, since i have 6 boards here - the one which is wired sure has all the links
i just scanned the spare one
Mongo1
PostPosted: Thu Jan 05, 2012 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Based on this and some other things we've talked about, I think you must be building the largest synth ever seen! Do you have a specific plan in mind, or are you just making it up as you go?
Gary
The Bad Producer
PostPosted: Thu Jan 05, 2012 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought so! Only things I could suggest - as per usual Very Happy is wiring, connections, soldering - you know the score! Also I remember mine acting oddly depending on how the trimmer was set (ie not working at all, being weird), though I don't remember that having anything to do with the controls...? The only other thing that has been a common issue with these is the pinouts of the transistors, but you would have noticed that for sure from all the other VCS problem threads! Again probably not relevant!
otherunicorn
PostPosted: Thu Jan 05, 2012 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've looked over your photo, and apart from that link, I can't see anything obviously wrong.
The value and type of pots used will actually have very little effect. They are not critical. My guess would be the transistors. Either you have the two types swapped, or you have got them from a manufacturer that uses a non standard pinout. If you have a transistor tester in your multimeter, put a new transistor from the same batch into it, and check. When the transistor is in the correct way, it will have a gain/Hfe in the 100's. If it is in backwards, the gain will be very low - probably under 20. I have seen circuits that manage to "work" even with all the transistors in backwards.
http://www.cgs.synth.net/
roman_f
PostPosted: Sun Jan 08, 2012 8:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
i will do that after the sleep, thank you for the tip!
though all the components are from elby kits
upd: as i've soldered all 6 kits - i think i have to desolder those transistors to check. won't be easy, as the wires are short.
do you think if the pinout may vary from different manufacturers?
roman_f
PostPosted: Sun Jan 08, 2012 9:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gary
dear Gary, 5 of those VCSs are going to be for sale in MU-format
i've discussed that with Ken and it it seems he's ok with that
i want to keep my 5U system pretty small now - my wooden case is 64U, but i will use only 2 rows of it now (instead of 4). other rows are for keeping some small boxes like drum-machines. i've sold most of the filters and specific modules in december. let's see how it goes. i still remember your request about making panels - i'll do the guide when i get the new camera, my lovely ricoh gr1 was broken by a 2-years old son :)
Mongo1
PostPosted: Mon Jan 09, 2012 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah! That makes sense. Good idea!
my lovely ricoh gr1 was broken by a 2-years old son Smile
Ouch.... Someone once told me that the reason children are so cute is to keep you from throwing them out a window. Laughing
Gary
roman_f
PostPosted: Mon Jan 30, 2012 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
dear ken
i've tried with 3906 - it's the gain is 230 when installed properly and 6 when reversed
roman
