PCBs for Thomas Henry's X-4046 VCO
Page 11 of 12 [296 Posts]
Goto page: Previous 1, 2, 3, ..., 9, 10, 11, 12 Next
pre55ure
PostPosted: Fri Aug 17, 2012 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry if this was asked before- but I couldn't find the information. Is it possible to run this VCO from +/-12v? If so, are there any components who's values need to be changed?
Really looking forward to building a couple of these!
PostPosted: Sat Aug 18, 2012 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
no need to change anything...
Posted Image
elanhickler
G2 patch files: 6
PostPosted: Sun Sep 02, 2012 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fonik, my build is a total failure Sad
Symptoms:
1.Turning coarse or fine pots causes pitch to change... except that it is slewed.
2. PWM Init pot is extremely sensitive, you can only hear a pulse output if the PWM init is exactly center.
3. Multimeter shows Pin 1 and Pin 2 of PWM Attn (PCB) connected to ground. The actual pot seems fine.
4. I get no sine output.
5. Triangle out is intermittent
5. Sync seems to work.
Crying or Very sad
PostPosted: Mon Sep 03, 2012 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
no so good, however, there is good news for you:
the project and the PCBs are well tested and build many times, so they are fine. something you can rely on.
so there must be at least one error on your side which you can troubleshoot and solve...
so i recommend troubleshooting as usual.
anyways, from what i understand reading your post, you have some issues with the waveshaper, and some with the core PCB.
i would recommend to completely remove the waveshaper board at first, and get the core board running. if the core board is fine, then add the waveshaper again to see what's the matter with it.
Posted Image
PostPosted: Mon Sep 03, 2012 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
so let us address it more specific:
so this is core related. as i said above, remove the waveshaper COMPLTETELY and then check again.
re 2 & 4: take a look at the schematic and how the pulse and PWM is done. you have a comparator IC4C that is fed with the sine. so as long as you don't have a sine ouput, you will not get a proper pulse...
re 3: if you removed the pot, removed the PCB completely from the system and still measure GND on pin 2 of the PCB header then there must be a short/solder bridge kind of thing... this pot is nothing but a voltage divider.
Posted Image
elanhickler
G2 patch files: 6
PostPosted: Mon Sep 03, 2012 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I removed the waveshaper. I have a patch cable going into my computer so I can hear what's coming out.
-Ground hum is coming from +/-15v power pins and ground pins.
-Ground hum is coming from ground pads (pad1) and signal pads (pad2) of the pcb (saw and tri pads)
-No waveshape or ground hum is present when cable is inserted into jack.
-I have all jack/signal wires going to pad2 of the PCB
-Check my LM394 connection.
Edit: NOTE I do have a second fully populated X-4046 that I could attempt to wire... or test?? Not sure what tests I'd do.
elanhickler
G2 patch files: 6
PostPosted: Mon Sep 03, 2012 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
here is my lm394 pic
 Filesize:  298.25 KB
 Viewed:  39832 Time(s)
PostPosted: Mon Sep 03, 2012 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
re ground hum:
1. re-check all your grounding/wiring.
2. connection to computer correct?
3. is your PSU clean?
4. what resistance do you measure across +V and GND, resp. GND and -V?
re LM394:
what transistors are you using? is the pin out correct? same as LM394?
Posted Image
PostPosted: Mon Sep 03, 2012 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
i see you did not socket the 4046.
hopfully it is still alive with no GND connected. i am not sure what this part can bear...
anybody?
Posted Image
elanhickler
G2 patch files: 6
PostPosted: Mon Sep 03, 2012 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Resistance across gnd/v+ and gnd/v-
Power on: Seems to be infinite resistance???
Power off: Resistance slowly falls to 0 and then goes back up to 2.2K for v+ and 1.45K for v-
Power on: No audible waveform
Power off: A high pitched waveform appears and quickly falls to 0hz at which point a waveform is no longer heard. Both saw and tri outputs exhibit this behavior and the waveshape seems to be correct for the brief moment I get the waveform during power down.
I used matched transistors 2N3904 from MusicFromOuterSpace.com
link: http://www.musicfromouterspace.com/analogsynth_new/ELECTRONIC_PARTS/Matched2N3904_MFTempco.php
PostPosted: Tue Sep 04, 2012 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
if you used 2N3904 transistors, then it looks like you have an error in the current mirror (Q1/Q2), according to your picture.
take a look at the 2N3904 pinout here:
Posted Image
and then take a look at the LM394 datasheet (edited by me):
Posted Image
if you wanted to use 2N3904 the 2nd transistor (pins 5, 6, 7 of the LM394 footprint) would have to be flipped. according to your picture the 2nd transistor is rotated...
Posted Image
elanhickler
G2 patch files: 6
PostPosted: Tue Sep 04, 2012 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Is that a typo? Isn't it 6, 7, 8? (5 is NC).
PostPosted: Tue Sep 04, 2012 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Yah, I'd say likely a typo. The bottom line is if you're using 2 NPNs of any sort, they both have to face the same way, they can't face one one way and one the other. Collector will always be the same pin on both, and if you reverse one to make them face each other, you're connecting collector to emitter and emitter to collector.
Audio files: 163
PostPosted: Tue Sep 04, 2012 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all ,
Is your faults occuring when the pcbs are stacked on the pillars ??.
It may be several shorts to ground, if it is causing shorts , just use thin nylon washers to isolate.
 Filesize:  70.47 KB
 Viewed:  39690 Time(s)
elanhickler
G2 patch files: 6
PostPosted: Tue Sep 04, 2012 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I got it working. I switched the transistors legs for "6,7,8" And the saw is supposed to be twice the frequency, right?
The waveshapes seem a little unclean to my ears. That's fine, but just want to make sure my build is as correct as possible. Can someone verify my waveshapes are as they should be? See attached wav file.
Edit: BTW, people describe the hardsync on this as VERY HARD and AWESOME... but I would describe it as very clean, that *is* awesome.
x4046-waveshapes.wav
 Filesize:  1.35 MB
 Duration: 0:08
 Viewed:  1959 Time(s)
PostPosted: Wed Sep 05, 2012 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
yay! that's it! Cool
the triangle is a composite of different ramp waveforms. you need the trimmers to set it up properly. and even with an optimum of calibration there will always be a small spike at the turning points of the triangle. some might call it a bug, i would call it a feature, since it adds to the flavour and personality of this VCO (it's always these imperfections that make it special, isn't it?).
the triangle gets shaped to a sine, and again, even with an optimum of calibration you won't get the perfect sine, it will have this little spike, too.
do you have a scope? this would be very helpful for calibration (connect the wave shapes, set the offsets).
Posted Image
elanhickler
G2 patch files: 6
PostPosted: Wed Sep 05, 2012 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, could you check that my core waveshapes are correctly trimmed before I add the waveshaper to the circuit? (see above wav). thank you!
elanhickler
G2 patch files: 6
PostPosted: Wed Sep 05, 2012 10:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK! Now I'm adding the waveshaper to the circuit and getting strange behaviors.
1. Sine output is 100% saw-shaped
2. Skew output is SAW ONLY and the skew pot simply turns the volume of the saw up or down. No triangle is heard
3. PWM init is extremely sensitive with the square output being inaudible most of the pot turn.
I checked pot values, I checked wiring... im using a header/pins for the saw/tri in/out. Maybe I have a bad connection there. Multimeter ran out of batteries so I need to recharge it before i can test for connection...
Read carefully: To test to see if the connection was bad I used an alligator clip that went from "TRIANGLE pin2" of the core to "SAW/TRI IN pin1 (triangle)" of the waveshaper. Basically, the waveshaper would in theory be receiving two triangle outputs into its one triangle input... both the "TRIANGLE" and "SAW/TRI OUT" from the core....
-Doing this made the sine output a weird shape in which the sine trimmers could affect, but it could not be trimmed to a sine. Before making this connection, the sine trimmers did nothing.
Any ideas? Thank you!
PostPosted: Thu Sep 06, 2012 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
okay, we should definately check the core's outputs before tackling the waveshaper.
the problem is: if you recorded this wave with your soundcard all DC offset will be removed, since the inputs of your soundcard are AC coupled (unless you modded it or bought a special soundcard for control voltage use).
nevertheless i will download the wavefile and analyze it.
on the waveshaper board you have at least two different issues, i guess:
1. sine wave (effects pulse, too, and might be due to some offset in the triangle).
2. skew pot (which is very plain and simple, so this should be an easy fix).
Posted Image
PostPosted: Thu Sep 06, 2012 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
if i got it correct then this is a kind of passive mixing, which i would avoid, especially when you want to test something.
i would just use the multimeter and check the continuity on the signal path. the core produces a triangle. so check continuity between:
core IC3 pin 8 and waveshaper pot R53 pin 3 (CW) directly on the pot.
here is a picture illustrating where you'll find the CW pin on a potentiometer:
Posted Image
Posted Image
PostPosted: Thu Sep 06, 2012 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
i looked at the waveorm you recorded using a wave editor. the waves look well connected to me, both the saw and the triangle, however, it is not possible to identify DC offset in a wavefile recorded via a soundcard.
nevertheless, when the saw ends in your file, i see a long slope going down to 0V. this could be due to an offset corrected by the AC coupling capacitor at the input of your soundcard. i am not sure.
Posted Image
elanhickler
G2 patch files: 6
PostPosted: Thu Sep 06, 2012 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fonik, smart call! HEY GUESS WHAT? VCO IS WORKING 100%!!!!! Sine is very unexpectedly clean!
I trimmed the saw and tri offset by repeatedly plugging and unplugging the waveform and watched how my audio interface removed the DC offset. So, if I plug in the waveform and it slopes up or down before settling, that means I adjust the trimmers until this doesn't happen. I'll have to re-trim when I have a method of actually seeing the DC offset.
So far:
-A transistor was reversed *FIXED*
-There was no connection from tri out of core to tri in of waveshaper *FIXED*
ONE little problem is left. My pulse init is still too sensitive. What parts should I check for correctness?
PostPosted: Thu Sep 06, 2012 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
ha! this is great news! Very Happy
before talking about the pulse, how does the sine wave look? maybe you could send me a wavefile from the sine output (m at fonitronik dot com)?
Posted Image
PostPosted: Thu Sep 06, 2012 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
R52 (330k), R49 (120k), R12 (2k2), in this order.
Posted Image
PostPosted: Sun Sep 09, 2012 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
i took a look at the wave file you sent me via emal, and indeed the sine wave seems to be a little bit weak compared to the other outputs. the shape looks quite fine though. no idea how to solve that by now. so for now re-check all components values again...
if you could live with that, and just want to get a better pulse width control, then let me ask the following: is it just the manual control that is unsatisfying, or do you find the CV control (PWM) too sensitive, too?
Posted Image
