Coming up on Radio 1 at
Wren latest version - 2025.4.10.0
Page 3 of 11 [263 Posts]
Goto page: Previous 1, 2, 3, 4, 5, ..., 9, 10, 11 Next
JLS
G2 patch files: 316
PostPosted: Mon May 11, 2015 11:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
same result with and without portaudio.dll
old version wren working fine
https://www.youtube.com/@kamilondrousek6973
https://soundcloud.com/1jls
https://soundcloud.com/user-819966312-266044932
https://github.com/jlswbs
https://www.instagram.com/ondrousek.kamil/
Audio files: 353
PostPosted: Tue May 12, 2015 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I can not find the error location you gave (0081B57) Confused
Could you try to rename the file wren.ini to see if it will then start?
JLS
G2 patch files: 316
PostPosted: Tue May 12, 2015 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
with and without wren.ini file same problem
 Filesize:  107.73 KB
 Viewed:  920 Time(s)
phobos
Audio files: 728
PostPosted: Tue May 12, 2015 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
let me give it a try,.. brb (I hope)
The Golden Shrimp Guild
phobos
Audio files: 728
PostPosted: Tue May 12, 2015 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
head banging monitor same thing happens here (00801B75)
Audio files: 353
PostPosted: Tue May 12, 2015 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok .. address was not 0081b75 but 00801b75 .. thats in my code .. seems to be in UpdateLights .. working on it now ...
Audio files: 353
PostPosted: Tue May 12, 2015 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made a new release 2015.5.12.0 ... some new code was trying to access a synth patch that did not exist yet ... http://bluehell.electro-music.com/wren/forums.html I think this will fix it.
Thanks for the heads up Smile
Made a new source code release for this as well.
edit : url update.
JLS
G2 patch files: 316
PostPosted: Tue May 12, 2015 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks Jan
New version working fine Smile
Audio files: 353
PostPosted: Tue May 12, 2015 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great :-)
Audio files: 353
PostPosted: Sat May 30, 2015 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
New release 2015.5.31.0 ... http://bluehell.electro-music.com/wren/forums.html#changes ... mostly clean up stuff .. but click link for details .. may have introduced some bugs .. changed the memory managment .. please let me know when its broken.
edit : url update.
Audio files: 353
PostPosted: Thu Jun 18, 2015 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
A couple of fractal thingies and some wave warpers, wire colors can be changed, please see http://bluehell.electro-music.com/wren/forums.html#changes for the full story.
Source code updated too.
edit : url update.
JLS
G2 patch files: 316
PostPosted: Fri Jun 19, 2015 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Chaotic attractors is great many thanks
Little idea:
- 1D and 2D cellular automata sequencer
- markov chain sequencer
- game of life sequencer
phobos
Audio files: 728
PostPosted: Fri Jun 19, 2015 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
instant crash here Crying or Very sad
old versions still run fine.
Audio files: 353
PostPosted: Fri Jun 19, 2015 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
instant crash here :cry:
Did it male a log file in the application directory? And if so .. can I please see that?
It is called wren.log when you did not change the exe name.
Audio files: 353
PostPosted: Fri Jun 19, 2015 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Will add those to the wish list .. thanks :-)
phobos
Audio files: 728
PostPosted: Fri Jun 19, 2015 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
here you go,. looks ok to me but I don't know what to look for.
have another txt file I'll get you later when I'm in chat.
wren.txt
renamed to txt since .log wasn't allowed as upload
 Filename:  wren.txt
 Filesize:  2.21 KB
 Downloaded:  740 Time(s)
Audio files: 353
PostPosted: Fri Jun 19, 2015 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup, that looks all fine .. is there any error message?
Audio files: 353
PostPosted: Fri Jun 19, 2015 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I did find a bug in the audio handling .. when it ever happens that there is no compiled patch and the audio stream runs the audio I/O processing will write out of the array bounds of the audio out buffer .. seems likely to be that .. on a slower system audio I/O may run before the patch got compiled. Also it would be worse with largish audio buffers, seeing your buffer size is 4096, using 512 or so here.
Audio files: 353
PostPosted: Fri Jun 19, 2015 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Posted a fix for that one as version 2015.6.19.0.
phobos
Audio files: 728
PostPosted: Fri Jun 19, 2015 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
well, I was going to change the settings after startup but because it crashes instantly I don't get a chance to do that.
However I assume I can change it in the ini file ?
I'll give the other version a try Smile
Audio files: 353
PostPosted: Fri Jun 19, 2015 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, you can change the ini file.
phobos
Audio files: 728
PostPosted: Fri Jun 19, 2015 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
version 2015.6.19.0 does not crash thumleft
so I guess that was indeed the problem.
Audio files: 353
PostPosted: Fri Jun 19, 2015 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great :-)
Audio files: 353
PostPosted: Sun Jun 21, 2015 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
New version 2015.6.21.0
Mostly cosmetics, a lil bug in envelope shape displays and updated some help text.
edit : url update.
Audio files: 353
PostPosted: Sat Jun 27, 2015 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some more cosmetics in 2015.6.27.0 and also removed some clicks from the basic envelope generator.
edit : url update.
