Tubbutec MIDI USB Bridge A
b-funk
PostPosted: Thu Dec 03, 2020 3:01 am    Post subject: Tubbutec MIDI USB Bridge A Reply with quote  Mark this post and the followings unread
***Mods: if you think this is inappropriate please tell me, then I remove this post***
Hey guys,
I'd like to introduce the new Tubbutec MIDI USB Bridge A module to the forum:
Midi USB bridge A is a dual USB host and TRS midi router and merger.
It allows you to connect two USB midi devices and one conventional midi device with each other.
https://www.youtube.com/watch?v=Fe592dyFS0U&ab_channel=Tubbutec
USB Bridge A features two midi USB hosts and conventional TRS midi (type A) input and output.
Midi data is routed between the connected devices and merged if necessary. Routing is very fast with very low latency.
Data received from a USB device will be send to the other USB device and to the TRS output.
Data received on the TRS input will be sent to the two USB devices.
Depending on the kind of data it will be merged, see below.
You can use this to:
Connect one or two midi USB midi controllers/keyboards to a conventional midi device
Connect a keyboard to a module with only USB device capability
Connect a cheap USB midi interface and get more conventional midi IOs
Use your phone to control your Eurorack or as a synthesizer
Connect a synthesizer via USB
Other notable features:
LED indication of connection and midi transfer status
Low latency
Merging of note midi data, special case handling for clock and Sysex midi data
Runs on 5V or 12V
Tested with a wide range of devices
Firmware update possible
https://tubbutec.de/usb-bridge-a/
 Filesize:  300.5 KB
 Viewed:  478 Time(s)
