Coming up on Radio 1 at
DIY desk synth without arduino
Page 1 of 1 [6 Posts]
Reza
PostPosted: Sat Dec 27, 2025 5:30 pm    Post subject:  DIY desk synth without arduino
Subject description: Can someone help me build a DIY synth please
Hi I'm making a DIY desk synth without an Arduino.
I have a midi keyboard smk25 with midi out into opto isolator then a dac then an opamp.
I want to play the notes on the keyboard and hear the note out the speaker.
Can someone please help me along the way with building it.
So after opto what do I need I can see the note on the oscilliscope and the led lights on note on and lights on note off.
Audio files: 32
PostPosted: Fri Jan 02, 2026 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
https://github.com/probonopd/MiniDexed
https://github.com/probonopd/MiniDexed/discussions
https://youtu.be/S6fjJ5Is0pg?si=QOy7bRoD8h-PsDau
I guess this will help you out!
Its not with an arduino, but uses an Raspberry Pie instead.
my synth
analogmonster
PostPosted: Sat Jan 03, 2026 1:41 am    Post subject: Reply with quote  Mark this post and the followings unread
If you try to avoid microcontrollers and programming in general you will need to do an exception with your MIDI interface AFTER the opto coupler.
Reza
PostPosted: Fri Jan 09, 2026 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just some images and a video of my circuit
VID_20251211_125106976.mp4
 Filesize:  105.16 MB
 Viewed:  170 Time(s)
 Filesize:  634.52 KB
 Viewed:  169 Time(s)
 Filesize:  846.46 KB
 Viewed:  159 Time(s)
 Filesize:  2.59 MB
 Viewed:  199 Time(s)
 Filesize:  3.18 MB
 Viewed:  202 Time(s)
Reza
PostPosted: Fri Jan 09, 2026 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Optoisolator
Dac
Opamp
Reza
PostPosted: Mon Jan 12, 2026 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
ive had to remove the 9v battery from the rails and use it to power the opamp
i need to get another 9v battery
