Warm leatherette Sound (technical inside)
Page 1 of 2 [26 Posts]
Eva_platinum
PostPosted: Fri Sep 02, 2005 8:14 am    Post subject: Warm leatherette Sound (technical inside) Reply with quote  Mark this post and the followings unread
Hi I'm working a on a cover of the song called Warm Leatherette by the Normal (daniel Miller ) on Mute.
Unfortunately I can't quite recreate the exact same Pitch Modulated synth sound...
I used a normal virtual synthesizer (being fairly young I didn't go through the whole analogue synth puchases) and I can recreate the pitch Modulatin effect without any problem but I can't get the sound because the LFO's and modulators affect both oscillators at the same time...(trust me it does and I can't separate them)
Then using the Virtual Instrument version of the Moog Modular ( one of my favourites) I can get close to the sound but I can't get the pitch modulation effect...
So if anyone could help me finding how to do it on moog modular or even by describing the settings I need for oscillators, LFOs, Modulators etc... to get that sound....
I'm asking on this forum because I know that I will get an accurate answer if I do get an answer...
Thanks
View user's profile Send private message AIM Address MSN Messenger
Audio files: 266
PostPosted: Sun Sep 04, 2005 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know this music, but I do have a lot of Moog Modular experience. I assume you have the Arturia. Anyhow, can you describe the pitch modulation effect?
Mohoyoho
PostPosted: Sun Sep 04, 2005 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I am also very familiar with Arturia's Moog Modular V2. You certainly can modulate the pitch on all 9 individual oscillators. But like Howard, I am not familiar with the sound you are trying to emulate. On the Moog Mod you can modulate the oscillators' pitch in a number of ways: LFO, another osc., the sequencer, an envelope, etc.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
Eva_platinum
PostPosted: Sun Sep 04, 2005 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
ok I'll try to describe it the best I can...
it's a sort of square wave ??? with a fairly slow attack... The first Lfo using a triangle or sinewave ondulation controls the volume creating a quick stutter effect...
And then while stuttering the pitch goes up in a quick glide effect....
I'll try to put an example online or something....
Eva_platinum
PostPosted: Sun Sep 04, 2005 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
here you can listen to the sound I'm after... it's the higher pitch synth i'm trying to get....
Cheers....
Click here to Listen What I'm on about
Mohoyoho
PostPosted: Sun Sep 04, 2005 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have tried several times, but can't seem to get the download.
Mark Mahoney
gsga
PostPosted: Sun Sep 04, 2005 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunately, I know the song well. But I don't know how you would get that sound. Sorry, that doesn't help.
"Pop music is for sheep and we are wolves disguised as shepherds."
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Sun Sep 04, 2005 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
It has been a long time since I heard that track. Mr Miller used pretty simple synthesisers in those days, I think it was done on a Mini Korg 700, the one with the ‘traveller’ filter which had a pair of super sweet, High/Low pass filters controlled by two interlocking sliders. I think it is just a combination of detuned oscillators*, fm from a fast square LFO, pitch bend up, and a dual peak band pass filter with high resonance and a lot of natural overdrive.
That’s from memory, I can’t listen to the example in your link as well.
* The Korg 700 initially had a single oscillator but a later revision included a second to beef up the sound. I wish I never sold mine.
Audio files: 266
PostPosted: Sun Sep 04, 2005 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
One can probably patch something like that up a Moog Modular. Laughing
Mohoyoho
PostPosted: Sun Sep 04, 2005 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah. I'm dying to hear it so I can give it a go.
Mark Mahoney
gsga
PostPosted: Sun Sep 04, 2005 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.mute.com/releases/viewRelease.jsp?id=27913
I think you have to add the song to the mute player to get it to work.
Mohoyoho
PostPosted: Sun Sep 04, 2005 10:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Apparently it requires Flash, which I don't have (nor will I). Too bad. I'd love to hear the synth.
Mark Mahoney
Eva_platinum
PostPosted: Mon Sep 05, 2005 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Well the example I put online is not for download (not my choice)... you can only listen to it by pressing the play logo on the website itself...
I don't have any link for places where I can upload them for you to download...
Mohoyoho
PostPosted: Mon Sep 05, 2005 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't even do that. THe site locks up my computer and crashes IE.
Mark Mahoney
Mohoyoho
PostPosted: Mon Sep 05, 2005 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Can't you upload a sample here? Or is that against copyright laws?
Mark Mahoney
Eva_platinum
PostPosted: Mon Sep 05, 2005 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
it is against copyright laws... unfortunately....
Well here is my MSN adress blixa_damaged @hotmail.com i can send it to you via MSn
Mohoyoho
PostPosted: Wed Sep 07, 2005 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm close but not exact. The key is that there are two oscillators out of tune with one another. I have a close representation of it for the Moog Mod V2. If you have that I'll send you my preset. Then you can tune Osc. 1 to taste.
Mark Mahoney
Eva_platinum
PostPosted: Wed Sep 07, 2005 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!!!!!!
Mohoyoho
PostPosted: Wed Sep 07, 2005 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's what I came up with. Osc. one needs to be tuned to what's in the song. It's not exact, but I think close.
Mark Mahoney
Mohoyoho
PostPosted: Wed Sep 07, 2005 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try tuning Osc. 1 to Coarse -2 and fine tune to 1.0595. It's still not perfect.
Mark Mahoney
Eva_platinum
PostPosted: Thu Sep 08, 2005 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
THank you so much for all the effort... I have had the time to listen to it yet... but I will today and let you know what I think...
I really do appreciate you helping me the way you did
Take care
thapoke
G2 patch files: 5
PostPosted: Fri Oct 07, 2005 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Warm leatherette was done on the korg 700s which had some pretty crazy ringmod in the effects section. i used to have a 700 (without the 's') and could get pretty close to the song by switching on the portamento and setting the envelope to retriger quickly then playing the bottom not followed by the top note , just like in the song!! i imagine if you ringmod that sort of sound youd get closer...?
Remember the minikorg had an always resonant hi pass /
low pass filter thing to.
PostPosted: Sun Oct 09, 2005 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Used to be one of my favourite songs.
Haven't heard it in 10 years or more.
What album was it on? Can you get a CD of it?
thapoke
G2 patch files: 5
PostPosted: Sun Oct 09, 2005 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can get it on cd from mute bank at http://www.mute.com/ecommerce/index.jsp
thapoke
G2 patch files: 5
PostPosted: Sun Oct 09, 2005 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
or still on 7" by the looks of it..
