PseudoStereo2
Page 1 of 1 [4 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Sun Nov 13, 2005 4:01 am    Post subject: PseudoStereo2
Subject description: 100% mono compatible
This is a laughably simple but effective technique to 'disperse' the frequency components of a mono signal over the stereo field:
Using a very short delay and mixing this back with the original creates a comb filter, boosting or cutting out components of the signal. Doing this a second time, inversely, cuts or boosts the exactly inverse components. Pan these two left and right -presto.
(Mixing them together produces the original mono signal: 100% mono-compatibility)
You can use a fixed delay time or modulate it to produce a chorus-like sound (but without the chorus-like "fattening" effect).
Enjoy
PseudoStereo2 TK.pch2
 Filename:  PseudoStereo2 TK.pch2
 Filesize:  1.33 KB
 Downloaded:  1907 Time(s)
Audio files: 267
PostPosted: Mon Nov 14, 2005 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
This one sounds much better to my ears than the other pseudostereo patch you posted. This is quite pleasant. Very special. Much better than what I've been using and cheaper in DSP too. bravo...
Wan
G2 patch files: 46
PostPosted: Mon Nov 14, 2005 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Your are definitly on the track of supplying us with all kinds of very useable broadeners and thickeners. It looks so simple, but this one rocks again Exclamation
Thank you again Very Happy
Grtz Wan
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Mon Nov 14, 2005 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, fantastic. Great that it sums to mono perfectly too, and doesn't sound off putting like alot of phase related stereo effects. And you can fix the movment of the filters and it doesn't sound off balance Shocked
This should be a G2 module IMO, extremely useful.[/b]
