Coming up on Radio 1 at
continuosly variable oscillator waveforms
Page 1 of 2 [45 Posts]
paul e.
PostPosted: Fri Dec 16, 2005 11:30 pm    Post subject: continuosly variable oscillator waveforms Reply with quote  Mark this post and the followings unread
i may be asking a painfully obvious question..
would anyone have any insights on how to programme an oscillator to 'morph' from a sine to a square, ramp etc over time?
Spiral Recordings
Audio files: 43
G2 patch files: 626
PostPosted: Sat Dec 17, 2005 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
The Moog Voyager has continuously variable triangle->saw->square->pulse controls on its oscillators. Not a common feature but I’ve seen how they do it thanks to data posted on a Voyager site. The triangle to saw section is a simple cross fade, saw to square combines cross fade and AM between the variable width rectangle and the sawtooth, the final section is your basic PWM from square to narrow pulse.
The technique used to morph only effects the in between waveforms, cross fading is probably the least interesting. The G2 shape oscillators have a true triangle to saw option, where the ratio of rise and fall times changes with the modulation signal. This is very hard to do on analogue oscillators but on the bright side, the effect sounds a lot like low pass filtered PWM, so no big deal.
You can use variable saturation (overdrive/clipping) to morph a triangle or saw into a square-ish wave.
paul e.
PostPosted: Sat Dec 17, 2005 2:15 am    Post subject: Reply with quote  Mark this post and the followings unread
cool..thanks for your interesting response
and i will try that simple solution you mentioned above
Spiral Recordings
aquanaut
PostPosted: Sat Dec 17, 2005 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
With Sounddiver you can import or draw all 64 waves of a microwave XT wavetable. If you put a sine as wave 1 and a square at 64 you get a morph for all remaining waves.
paul e.
PostPosted: Sat Dec 17, 2005 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
nice !
Spiral Recordings
Audio files: 21
PostPosted: Sat Dec 17, 2005 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
This ain't your Daddy's oscillator!
paul e.
PostPosted: Sat Dec 17, 2005 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah right on !... the 'sequence' mp3 on that site demonstrates this well
Spiral Recordings
Audio files: 21
PostPosted: Sat Dec 17, 2005 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
The Plan B Model 15 has CV controlled morph too. Cute.
http://www.ear-group.com/model_15.html
Mohoyoho
PostPosted: Sat Dec 17, 2005 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
This might be obvious and not what you are looking for, but in an instrument like the Voyager or some soft synths, would not using an envelope generator to modulate the wave form do the trick? or a slow LFO?
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
paul e.
PostPosted: Sat Dec 17, 2005 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
funny , yes i did think about that, but like you, thought it might be too simple..but maybe it's just the trick...will try that out as well
Spiral Recordings
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Dec 18, 2005 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
right, but not on OSX because that f***ing application has never worked under OSX Evil or Very Mad
aquanaut
PostPosted: Sun Dec 18, 2005 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
try with MidiBridge9X 0.90
http://www.versiontracker.com/dyn/moreinfo/macosx/22653
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Dec 18, 2005 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
allows OMS MIDI communication under Classic
are you kidding me Question no Classic, no way Wink
Kassen
PostPosted: Sun Dec 18, 2005 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Í don't understand any of this discussion. What are you programing in? What way should they morph? You see; you can make anything into a square by clipping it but that's not the smoothest way of doing it. You can probably crossfade in many systems but that does depend on either sample acurate math or sample accurate sample playback.
as long as you just want to go from one shape to another and don't particularly care about all the details then I'd take a stereo sampler, put a sample in it with the two waves, one panned hard left, the other hard right, get both outputs to the centre position of my mix and take a pan controler to the sampler. It's cheap, easy, dependable and it's going to glitch if that pan isn't smoothed before being applied. More advanced samplers might allow for controler or envelope based crossfading between two or more samples. Multi samples should give you sample acurate playback for free but that depends on you finetuning your samples (which here would be more acurately called wavetables).
The world is your oister here; you can make it as complex or simple as you want it. A second hand esi-32 will do it for you for peanuts. Matlab will also do it, matlab will potentially do it in a much nicer and more interesting way at the cost of your social life ;¬)
Kassen
Mohoyoho
PostPosted: Sun Dec 18, 2005 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's what I do. The Voyager has the variable waves from sine to square. I love modulating it with one of the mod busses or with one of the envelope generators. There's a CV input in the back of the V'ger that give you a direct input so you can use an outside CV as well. The busses are already hardwired to modulate the waves. Unfortunately the input in the back modulates waves on all three osc. at the same time and not individual osc. My Q lets you modulate the different oscs' waves.
paul e.
PostPosted: Sun Dec 18, 2005 10:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
it's a good idea in itself, but does not provide a 'continuosly variable' wave form shape..it's just cross-fading between just two distinct waveform states
i discovered the Korg Prophecy has a 'waveshaping' parameter that will alter the waveform shape over time...am looking into that as well
Kassen
PostPosted: Sun Dec 18, 2005 11:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I know that, in fact I noted exactly that in the half-phrase just before the bit you quoted.
This would be much easier if I knew exactly what it is that you want to program and what you want to program it in.
Did you considder that if phase is no issue then additive synthesis might actually be a viable option here? You might not actually get a square or saw but you will get the sound of those and implementing the morphs would be quite straighforward. You could add a check that compares individual harmonics's eventual frequency to the nequist and mute them if they end up over it; that would do quite nicely as a anti-aliassing strategy.
Kassen
paul e.
PostPosted: Mon Dec 19, 2005 1:00 am    Post subject: Reply with quote  Mark this post and the followings unread
interesting..i do have access to a basic additive synth..[the kawai k3]
but the harmonic wave editing parameters seem pretty esoteric on the 10 character LED displayhehe
Spiral Recordings
Kassen
PostPosted: Mon Dec 19, 2005 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that sounds like a chore and I supose that once you have one implementation you can do it all over again next time you need a different morph.
To realy be able to get any arbitrary wave-morph that you may want you are going to need something modular, practically speaking (though I maintain that a decent sampler with multisamples might get you by). The problem is also that unless you can set your morph to some NRPN it's going to glitch unless parameters are smoothed internally. This is one of those wonderfull subjects that manifactureres see no need to document in manuals. It would be a good idea if samplers and synths would have a option to delay the application of CC's untill the next zero crossing and for all I know some do. I wouldn't bet on it though.
Next up; most softsynths are going to choke on a dozen or more arbitrily defined oscilators for a good number of voices. That's not a fundamental (no pun intended)problem; you could render offline.
Basically I think your choices come down to making do with what manifacturers have already implemented (which will typically be a fairly limited fairly concervative range of options from a theoretical point of view but quite effective musically) or improvise something and just swallow the glithces or cook up your own. If all else fails then my proposed strategy implemented in Csound *will* get you what you want with all hamonics up to the Nequist, no glitches and no aliassing at all for any number of voices. It won't be that much fun and in all likely hood it won't be realtime either but it *is* going to work.
I don't think that's worth it since clever use of filtering and various kinds of waveshaping can get you quite close to the sound you'd get that way with much less trouble but then again; I have no idea how badly you need morphed waveshapes.
Kassen
paul e.
PostPosted: Mon Dec 19, 2005 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
so bad i can taste it..hehe no just kidding..just a fascinating idea to me right now...also thinking about an alternative method of sequencing an album of trax, by applying a similiar concept of variable waveform shapes..i.e. analyzing the 'shape' and therefore the order of how the trax appear on the album , based on either tempo or some subjective 'feel/groove' parameter as the 'envelope'
and i appreciate your input/insights
Kassen
PostPosted: Tue Dec 20, 2005 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, ok.
Well, if it's such a conceptual thing I would indeed tackle it on the waveshape level instead of a sound/harmonics one. In that case I think a modern (soft?) sampler with multi samples might be your best bet. Try and find one that can use a parameter like modulation to X-fade between samples. That's not so rare or exotic but mostly those get used to X-fade based on velocity and typically people use presets (think of those multi-gig pianos). It's of cource vitally important that you cut all of your samples to have their zero crossings at the same point.
It's a realy interesting problem; you'd think there would be mor ready made solutions because it's not such a outlansish plan at all.
Kassen
paul e.
PostPosted: Tue Dec 20, 2005 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
yes indeed, i agree...
Spiral Recordings
ndkent
PostPosted: Mon Jan 30, 2006 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Serge built a VC waveshaping circuit into their NTO (their higher end VCO). It apparently starts with saw, shapes that into a sine and then into a variable pulse. Enough modulation voltage will take through all of them or attenuated modulation will keep you within a limited range.
I suspect Modcan built their 12a Morph / Peak & Trough based in some part on Serge's designs. It proves that the circuit is a genuine waveshaper rather than crossfading waves since with modcan module you supply your own saw wave externally (...or any other wave which of course makes me curious what other waves will do if processed, I have an NTO which is hardwired to a saw and has linear FM, but no external wave input like Modcan).
Finally Serge makes a Waveshaper that inputs an external saw and VC shapes that into a sine. Their "entry level" osc, the PCO doesn't have a sine output so this module might have been a unique way to produce one. At the moment no one has a similar or copied module.
nicholas d. kent
http://technopop.info/ndkent/
paul e.
PostPosted: Mon Jan 30, 2006 9:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey, now that sounds fun ...
Spiral Recordings
morbius
PostPosted: Sun Feb 12, 2006 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well.... Ok... let's assume that one wants or needs to patch a modular system to 'morph' from one waveshape to the next.
Output all four wave outputs, each to it's own VCA. Use a sequencer (set to four-stages) to control when each VCA opens. Ta da.
~Morbius~
www.unisynth.com
