Display Controller value (MIDI- in) to Knobs
Page 1 of 1 [5 Posts]
sepp8
PostPosted: Fri Mar 03, 2006 9:51 am    Post subject: Display Controller value (MIDI- in) to Knobs Reply with quote  Mark this post and the followings unread
I try to display the MIDI values from MIDI Controller In to the Knobs display, but I am stucked. Is it possible ?
It is for remote control of VST-PlugIns with a "Controller Dump on Programmchange" (f.e. Native-instruments B4).
Audio files: 266
PostPosted: Fri Mar 03, 2006 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome This is your first post. Great to have you here.
Just take a constant module and assign with right-click the knob to the MIDI CC you want to show. Then assign the constant modules knob to a panel knob. Here's a simple patch to show you how to do it.
All you need is the module in green. The stuff in grey is just to send a MIDI CC and to play a sound for demonstration purposes.
Midi in to knob.pch2
Building Block to assign a MIDI CC input to a panel knob. Must be run in Slot A.
 Filename:  Midi in to knob.pch2
 Filesize:  1.27 KB
 Downloaded:  3181 Time(s)
sepp8
PostPosted: Fri Mar 03, 2006 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks very much, it works well !
BobTheDog
Audio files: 32
PostPosted: Sat Mar 04, 2006 12:33 am    Post subject: Re: Display Controller value (MIDI- in) to Knobs Reply with quote  Mark this post and the followings unread
sepp8 wrote:
Why don't you use the "midi control automate" module?
I use this to control Vst's and it updates its value from the value the vst sends out on programchange or if the parameter is edit in the vst.
Is this what you need or am I confused?
Andy
sepp8
PostPosted: Sat Mar 04, 2006 1:17 am    Post subject: Re: Display Controller value (MIDI- in) to Knobs Reply with quote  Mark this post and the followings unread
Andy
Yes, that the right module I am looking for !
Is there a Database of G2 Patches, controlling VSTs ?
reinhold
