another little problem with NL1
Page 1 of 1 [9 Posts]
Natureboy
PostPosted: Mon May 25, 2009 2:57 pm    Post subject: another little problem with NL1 Reply with quote  Mark this post and the followings unread
Hello i'm back again, thank you for the answer in my last question, now i dont have anymore that problem.
I noticed anyway another problem:
sometimes when I'm starting the keyboard the programs I've saved before in the Program Slots (A, B, C, D) are all reset to 1, 1, 1, 1.
What it could be?
Thank you
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon May 25, 2009 4:10 pm    Post subject: Re: another little problem with NL1 Reply with quote  Mark this post and the followings unread
Natureboy wrote:
... the programs I've saved before in the Program Slots (A, B, C, D) ...
You can't save into a Slot, only into a memory location. Do you also loose the sounds?
Wout
Natureboy
PostPosted: Tue May 26, 2009 4:45 am    Post subject: Re: another little problem with NL1 Reply with quote  Mark this post and the followings unread
Wout
Sorry i've explained my problem badly.
I mean when I'm playing the keyboard, I'm using for example the program n°56 on Slot A, then I set the n°68 on the Slot B, the n° 43 in Slot C and the n°10 on Slot D, when I shutdown the NL sometimes when I restart the keyboard I have the program 1 on the Slot A, the program 1 on the Slot B, the program 1 on Slot C and the program 1 on the Slot D. But this doesnt appears every time, just sometime, most of time when I restart the keyboard I have the setup I had when i've shutdown it.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue May 26, 2009 6:33 am    Post subject: Re: another little problem with NL1 Reply with quote  Mark this post and the followings unread
Natureboy wrote:
... most of time when I restart the keyboard I have the setup I had when i've shutdown it.
Which is normal.
I don't know what makes the synth switch to #1...
Maybe there is some Midi data coming in which is resetting the synth? Try it without Midi cables connected...
Wout
Natureboy
PostPosted: Tue May 26, 2009 9:44 am    Post subject: Re: another little problem with NL1 Reply with quote  Mark this post and the followings unread
Which is normal.
Wout
I dont have any MIDI device connected. When I'm starting it an "E" appears always on the display, but just at start, maybe an error?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue May 26, 2009 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, it means the Expansion board is placed.
Wout
hiddenthink
PostPosted: Sun Aug 23, 2009 12:16 pm    Post subject: NL1 power-on issue
Subject description: "E" display on power-on with no expansion.
Wout
Hi.
When my NL1 doesn't completely freeze upon power-up, it displays 2.6 then E, then starts up. First, Theres nothing in the dusty card slot. What's weird is it turns off MIDI control of LFO's and ruins this 1 patch that uses them. Is it a bug I've created, or did I get ripped-off on craigslist?
Thanks.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Aug 23, 2009 12:57 pm    Post subject: Re: NL1 power-on issue
welcome hiddenthink
The Lead can freeze up when it is receiving Midi data at the same moment.
Is there just a slit in the red hood or is there something in which you can insert the card in? If so, it's expanded, even when you haven't inserted a card.
Special functions aren't saved in Program mode, only in Performance mode [See Manual page 56], which is only to be saved on a PCMCIA card, which, I believe, isn't inserted. So, no strange behavior.
This I can't tell you, if you are ripped-off. It's up to you to decide this. I am only trying to help you with some of the disappointments and frustrations: you expected something and until now this isn't there yet!
Wout
hiddenthink
PostPosted: Sun Aug 23, 2009 5:05 pm    Post subject: Re: NL1 power-on issue [SOLVED]
Exclamation Thank You - it is no longer freezing at power-up. Exclamation
Just a (empty) slit in the case labeled: PCMCIA slot.
I assume all I need is one of those little cards, and not some special expansion case to hold a card.
I still displays 2.6 then E on startup. I swear it didn't do that before.
This is an amazing machine. I can't wait to find a card and some new pots for it.
Thanks for the help WoutBlommers!
