Coming up on Radio 1 at
pixels & scanlines
Page 2 of 2 [33 Posts]
Goto page: Previous 1, 2
Audio files: 730
PostPosted: Mon Jun 06, 2022 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
and some more photos,..
 Filesize:  240.57 KB
 Viewed:  344 Time(s)
 Filesize:  418.51 KB
 Viewed:  373 Time(s)
 Filesize:  415.24 KB
 Viewed:  347 Time(s)
 Filesize:  391.66 KB
 Viewed:  339 Time(s)
 Filesize:  286.38 KB
 Viewed:  357 Time(s)
The Golden Shrimp Guild
Audio files: 730
PostPosted: Sun Jun 12, 2022 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
You can see it in action in the following video: https://youtu.be/tjxw84iRoFg
also still on twitch which probably has better quality https://www.twitch.tv/videos/1501105860
This was a test between the capture method I have been using (cheap composite to HDMI upscaler/converter
+ generic HDMI capture device) on the left and a more expensive Elgato Video Capture device on the right.
All the music I played was created by Muied Lumens and can be found here
Audio files: 730
PostPosted: Fri Jul 15, 2022 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
recent video feedback experiments, using video mixers, color corrector and a camera + CRT.
I got the camera setup a little bit better but I think it just doesn't really have a suitable lens.
It does give a nice spherical effect though.
https://youtu.be/c0K8GSeX56k
or the cropped and resized 4:3 version
https://youtu.be/BFfJSkS02Yg
all music by Muied Lumens (see video description for more info).
Psyingo
PostPosted: Sun Jan 22, 2023 11:59 am    Post subject: Original Sima Edit 2 Schem Reply with quote  Mark this post and the followings unread
Could you post the original (unmodified) schematic for the Sima Edit 2? I believe the enhance might come from the section on the main board? the section that looks similar to the AVE doesnt have a cap on the emitter of the pnp, so it's actually just functioning as an amplifier without high frequency boost.
Audio files: 730
PostPosted: Sun Jan 22, 2023 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is what I got, can't promise it's 100% correct.
'Video Enhancer" connects to the pot of the other schematic.
 Filesize:  77.48 KB
 Viewed:  331 Time(s)
irony7
PostPosted: Fri Aug 14, 2026 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
The video section has 2 chips of which the numbers have been ground off so I don't know what they are
but one of them is likely a comparator for sync extraction.
Newb here, and happy to be here. Dunno if this will help or if of any interest at all in an old thread, but...
I'm dissecting a Sima Video Ed/it 2 and ran into a similar situation you had - but rather than the chip identifiers being ground off, the central section of the board including the cips was spray painted. After some judicious cotton swabbing with isopropyl alcohol and a little, very careful forensic scraping, the chip identifiers are visible.
The dip 16 chip is a BU4538B retriggerable/resetable monostable multivibrator. The dip 8 chip, of which pin 8 is connected directly to pin 3 of the BU4538B, is an LM393 dual differential comparator.
Reading through your schematics, planning to follow your general plan for creting the video glitch section. And thank you so much sharing your wonderful schematics!! [/quote]
 Filesize:  421.68 KB
 Viewed:  88 Time(s)
Audio files: 266
PostPosted: Fri Aug 14, 2026 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
irony7 welcome to electro-music.com good to have you here.
Here old posts are rarely deleted as so many have useful information.
Audio files: 730
PostPosted: Tue Aug 18, 2026 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome party!
Oh, that's great! Very Happy
I more or less guessed the comparator would likely be a LM393, but expected the other one to be some kind of special video chip.
The BU4538 being a multivibrator does make sense. I might update the schematic with that new info.
note: I fixed the quote formatting in your post, hope you don't mind.
