S/H => bitcrusher-style
Page 1 of 4 [84 Posts]
Goto page: 1, 2, 3, 4 Next
bugbrand
PostPosted: Wed May 03, 2006 6:48 am    Post subject: S/H => bitcrusher-style Reply with quote  Mark this post and the followings unread
A sample&hold should work fine as a sample-rate-destroyer, right?
(I was thinking bit-crusher, but that's bit depth whereas this is sample rate)
I was thinking to make use of the AD781s I got from Analog.com -- they're 8pin dip Sample & Hold amplifiers... Should be as simple as making a variable speed pulse-osc ranging from 44.1k down to ... low..?..(plus, of course, preamping etc)
Or am I being wrong?
***EDIT***
Read through this thread for details on the AD781 based Audio Sample Rate Reducer design - the BugCrusher
There are two schematics hosted on electro-music on this thread:::
http://electro-music.com/forum/topic-13444.html
http://www.bugbrand.co.uk
Audio files: 266
PostPosted: Wed May 03, 2006 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
s-h.mp3
Sounds like this
 Filesize:  330.68 KB
 Duration: 0:21
 Viewed:  4432 Time(s)
Looks like this
 Filesize:  22.79 KB
 Viewed:  60484 Time(s)
bugbrand
PostPosted: Thu May 04, 2006 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Howard that sounds ACE! Yes, super simple..
BUT! I tried out with the AD781 yesterday and I got masses of signal bleed from the sample-trigger signal..
The 781 requires very few extra parts so breadboarding was easy - fed a function gen in but you require very short pulse signals, so I added a pulse converter with two 40106 gates.. Lots of bleed through. argh, so I tried making another of the 40106 gates into the osc (thought this may help..) - still loads of bleed through (..the sample-trigger signal needs to be 0-5v whereas the rest runs at +/- 12v)
The sounds, apart from the bleed through, were really gnarly and good.. May make a good lofi effect.
I'll try some more ideas out today..
DARN - and I REALLY need to get my MicroModular back again (..its currently been sitting in london for a few months..)
Audio files: 266
PostPosted: Thu May 04, 2006 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the 781 seems to be a little bit different than the NM S/H module in that it is not edge triggered.
Posted Image
Maybe if you clock it with a square wave oscilator with a adjustable pulse width you'd get good results.
bugbrand
PostPosted: Thu May 04, 2006 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
YES - more findings = things sound good!
You're right Howard - the problem was with the non-edge triggering. I'd kind of figured that yesterday - 'cos it was working like a sqr-wave trem at low rates.
Well, I adjusted some things and found that its very simple to make something pretty darn ace - and the bleedthrough is almost gone by making the Sample trigger pulse really narrow (it could probably go even narrower..)
So, I did a quick schematic (which shows just how simple it is..):
Proto RateReducer Schematic
And uploaded a couple of quick demo sounds of a 505 and a guitar going through it (..this was using a modular preamp to boost the signals first and then going out through modular mixer - so treating this circuit as a new processing module.)
505 and guitar
guitar hits - good drum sounds?
bugbrand
These chips are available as free samples from analog.com too..!..
Audio files: 266
PostPosted: Thu May 04, 2006 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds good. A certain amount of bleed through is to be expected with this kind of circuit.
Nice cheap narrow pulse oscillator you have built, BTW...
bugbrand
PostPosted: Fri May 05, 2006 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
..yet another tip from the ever-useful Music From Outer Space - Micky Mouse Logic
I really feel the need to make this voltage controllable (have the rate controlled) - - so how to simply turn a 40106 into a VC(LF)O? ...
Well, looking on René Schmitz's site, there's the drive part of the 3phase LFO - the drive part is here made from 1/4 of a 4093 with the two inputs tied together - so I figure a gate of the 40106 can replace this.. Hope to try out asap 'cos I want this module built already.!.
dnny
PostPosted: Fri May 05, 2006 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice samples from both.
i placed a sample order from analog.com, so this is soon under my soldering iron
www.koelse.org
flickr: cable porn group
piedwagtail
PostPosted: Fri May 05, 2006 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Good work Tom,
Any reason i can't do this with the LF398?,i have a stash of early cans.....
being not so needy of the ultra-scramble Smile
putting a LDR around the 1M pot might be feasible for mild changes.(empirically parallel or series)
and a LDR/vactrol vc-mixer to vary the clean to scramble mix.
Is Farnell,via Newark,the only way to get vactrols over here?
The £12.95 postage is pain for $1 devices....
Robert
dnny
PostPosted: Sat May 06, 2006 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
you can always roll your own - take a look at these sites to get started:
Motohiko Takeda demonstrates his method
Scott Stites article on how to experiment with "rolling your own"
Grant Richter's Hairball
topps Hairball
www.koelse.org
piedwagtail
PostPosted: Sat May 06, 2006 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Takeda reverse viewing roundhouse.... Wink
 Filesize:  31.89 KB
 Viewed:  60372 Time(s)
PostPosted: Sat May 06, 2006 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I love those samples!
Well done.
toppobrillo
PostPosted: Sat May 06, 2006 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds good!
bugbrand
PostPosted: Sun May 07, 2006 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers.
I fully intended to try out the VC rate control idea yesterday,
But then I got a Modular G2 Rack.. so I didn't have any time left over (not surprising really - the G2 is freaking amazing. Really, I don't know any system that comes close to its wonders)
But I will try to investigate tonight -> G2 or not, still got to make more synth modules..
dnny
PostPosted: Sun May 07, 2006 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
happy to hear that your not leaving the DIY for one rack:)
and congrats for the new awesome G2
www.koelse.org
Audio files: 266
PostPosted: Sun May 07, 2006 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats on the G2...
IMHO, the G2 makes a superb platform for debugging ideas for DIY circuits.
toppobrillo
PostPosted: Sun May 07, 2006 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, definitely, i have been using the demo and though my PC will only allow me to run about 8 modules or so, [yeah its pretty slow] i have been able to experiment instantly with ideas that i wouldn't otherwise or would have taken hours to breadboard and test.[not to mention tearing down whats already breadboarded.] so yep tell your friends about it. free sound circuit prototyping software.
bugbrand
PostPosted: Mon May 08, 2006 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
piedwagtail wrote:
Good work Tom,
being not so needy of the ultra-scramble :)
Robert
Thanks Robert -
I don't really know the LF398 - maybe its an edge triggered device and therefore EVEN EASIER to use than the AD781?
piedwagtail
PostPosted: Mon May 08, 2006 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Tom,
LF398:I'll have to do my homework,i've used them in Grenader S/Hs without difficulty.
I'm knee deep in oscillators at the moment,so i'll wait to hear your forthcoming voltage controlled samples Razz
If you're up to London,i can add another rack:a 4.5U sub frame,used to be a Wayne Kerr ballistics analogue computer.Fits a 19" and has 5 plug in cards.(Don't think i'll fit it in my lifetime achievement schedule Rolling Eyes )
Robert
PostPosted: Tue May 09, 2006 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
"Wayne Kerr"!!?? Shocked
That's got to be a joke right? Laughing
piedwagtail
PostPosted: Tue May 09, 2006 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
The build quality is formidable....http://www.waynekerrusa.com/
http://www.waynekerrtest.com/
PostPosted: Tue May 09, 2006 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like a fine company.
It's just an unfortunate name.
Audio files: 21
PostPosted: Tue May 09, 2006 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle, I know what you mean. Laughing
Wayne is the best, besides Jesus.
http://www.independentbands.com/cd/waynekerr/brandnewday.html
Wayne Kerr's music meets two very important criterias, his music is both annoited and cutting edge.
okdokey
Flickr
Audio files: 21
PostPosted: Tue May 09, 2006 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
However, that hardware looks like some serious shit!
wave
Flickr
